Smart Lighting activity feed bug?
#1
Hi all, I recently configured a new automation using Smart Lighting and whenever I use sunrise/sunset offsets it sends numerous ON/OFF commands to the switch. A quick count of each: at least 25 ON commands were sent during the sunset trigger with offset, and about 36 OFF commands were sent during the sunrise with offset.
If i turn the offsets off, I only get one ON/OFF command sent for the triggers.
Any ideas? Thanks!
Edit: screenshots attached
Smart Lighting Automations Broken for 8 Months
(sidjohn1) #2
This should be reported to support. support@smarthtings.com
#3
Thanks, it looks like the exact same problem I’m having. Will give support a try.
(Jim) #4
I’m having the same issue, and have a ticket into support as well.
As you had described, my issue currently seems to be with two switches triggered at sunset with a +/- offset as well. 20-40 commands sent.
Performance is still as intended, and lights turn on when they’re supposed to, so it’s probably a low priority.
(sidjohn1) #5
priority is set by how many users report the issue, if you would like it resolved sooner then “a matter of weeks” then i would report it to support as well.
(Doug) #6
I see it too. Will report as well.
Does anyone have a workaround? I like to check my activity feed regularly just to check on how things are going, and this really corrupts the view.
(Jim) #7
I agree it does. ST staff ran a script on mine, but it did not fix the issue. Continues to repeat the commands that are triggered at sunrise/set with time offsets.
#8
I’m also having the same issue but it also has repeated activity messages for routines too. This may not be limited to just the smart lighting app. I sent an email to support and have a ticket open. Hopefully we see some movement on this because its annoying to see all that noise in the feed.
Edit: Just got a response from support. They are escalating it to the engineers, ill post an update when I hear something.
(James Ward) #9
Same here. Is this still an issue for others?
(Richard Eisenberger) #10
yup, same here… and seems to be getting worse .
I’ll put in a ticket as well
