Hello,
It appears that SmartApps (webCoRE and SmartRules) are not receiving/seeing state changes of my simulated switches.
The switch state changes do appear in the Notifications-Activity Feed although its “Status” is “INACTIVE.”
I’m effectively brand new to ST. How do I go about debugging this issue?
Thx
which simulated switch device type did you use? you then added the new device to those apps so they have access?
“Simulated Switch” is the device type.
Yes, the simulated switch has been added to the webCoRE and SmartRules and I’m able to create pistons/rules in both but neither works.
That said, I believe the same simulated switch functions properly in the native “Smart Lights” SmartApp.
