If all 3 are installed, does that cause an issue? I have had all 3 installed since Jan when I got my SS alarm and it worked great until about 4 weeks ago, haven’t been able to get it to work since.
That first message is your next place to check (not sure what the second one is-it has a different ID so not the same app)
You should look at these two things:
Confirm you have something set for night mode
Check to make sure your SimpliSafe device is reflecting the correct arm state first. If the device already thinks it is in home mode, it’s not going to resend the arm home command to SimpliSafe. This is by design so as not to spam the SimpliSafe servers.
You really should only need one of the smart apps. They do basically the same thing. Mine sets the alarm based on mode. @tobycth3 's sets the alarm state based on smart home monitor. I would pick one or the other.
Hey Rick,
Sorry for the late reply. I would suggest using either mine or @foxxyben code and not all of them combined. You SHOULD be able to chose whichever Device Handler and SmartApp fits your needs but having all of them installed at once could cause some strange things.
If you are using my SmartApp, it ‘remembers’ the last action based on a stored state value. ST has been known to corrupt this sometimes (although its not that common anymore) so maybe a simple remove/reinstall might straighten things out.
Ok this is the first custom DTH and Smart App I am trying. I see early in the post that there was a way to specify the location ID from the simplysafe URL. I have multiple locations on my SS account and it is pulling the first one in the list, I cannot find where to enter that location ID anywhere in the smart app or device preferences?
Is the SmartApp code on top of thread the latest? It shows dated 3/5/16, but it looks like last update was supposed to be 5/10/16? If it’s not the latest, where can I get the latest version? Thank you!
