Shut down PC using Google Home and SmartThings?
I can’t find any documentation that there is an API available for OMV that would allow for doing a shutdown via an HTTP call. If there was and assuming you have a ST hub, you could create a virtual device to represent the PC and tell Google to turn it on/off. Then in ST, you could use the Web Requestor Edge driver to send the web request to your PC when the virtual device is turned on/off.
