Shut down PC using Google Home and SmartThings?
Hi All,
I have a PC (running Open Media Vault) in my home and I am looking to shut it down using a Voice Command like “Ok Google - turn off computer” - which will essentially execute a shutdown command to turn off my PC - can this be done via ST Hub?
I can’t find any documentation that there is an API available for OMV that would allow for doing a shutdown via an HTTP call. If there was and assuming you have a ST hub, you could create a virtual device to represent the PC and tell Google to turn it on/off. Then in ST, you could use the Web Requestor Edge driver to send the web request to your PC when the virtual device is turned on/off.
hi try messaging @TAustin i think he might be able to help.
martin
It’s not hard to do from Google Home without a ST Hub. One is not dependent on the other.
Google Home Script Editor opens up a whole world of possibilities that you cant really do with the app. With that being said if you don’t care if you are saving whatever then plug your PC into a smart outlet , code your script , turn it off via script
If you want to graceful then therei are multiple ways to do it some of which have been discussed in this thread.
thanks @OpethNJ - Let me explore Script editor.
Which thread are you referencing?
Sorry about that , you think I would know better than to replay at 4am or whatever it was.
Anyway, if you have IFTTT this becomes even easier.
SwitchBot has integrations with both Google Assistant and SmartThings. One options is to get a SwitchBot Bot to press your computer’s power button and a Switchbut Hub. I do it to turn on my computer when I arrive home or via Alexa.
I was thinking on that @TenchiMisaki but dont want to keep adding more devices.
@OpethNJ I dont have IFTTT, but let me see what they did and maybe I can repurpose. Ty
