metadata {
definition (name: “Shelly1or2”, namespace: “patrickkpowell”, author: “Patrick Powell”) {
capability “switch”
attribute “ip”, “string”
simulator {
// TODO: define status and reply messages here
tiles(scale: 2) {
// standard tile with actions named
standardTile(“switch”, “device.switch”, width: 2, height: 2, canChangeIcon: true) {
state “off”, label: ‘{currentValue}', action: "switch.on",
icon: "st.switches.switch.off", backgroundColor: "#ffffff"
state "on", label: '{currentValue}’, action: “switch.off”,
icon: “st.switches.switch.on”, backgroundColor: “#00a0dc”
// the "switch" tile will appear in the Things view
main("switch")
preferences {
input("ip", "string", title:"Address", description:"Please enter your Shelly's I.P. address", defaultValue:"" , required: false, displayDuringSetup: true)
input(name: "Relay", type: "enum", title:"Relay", options: ["0","1"], displayDuringSetup: true)
section() {
input("HTTPAuth", "bool", title:"Requires User Auth?", description: "Choose if the HTTP requires basic authentication", defaultValue: false, required: true, displayDuringSetup: true)
input("HTTPUser", "string", title:"HTTP User", description: "Enter your basic username", required: false, displayDuringSetup: true)
input("HTTPPassword", "string", title:"HTTP Password", description: "Enter your basic password", required: false, displayDuringSetup: true)
def parse(description) {
log.debug “Parsing result”
def msg = parseLanMessage(description)
def headersAsString = msg.header // => headers as a string
def headerMap = msg.headers // => headers as a Map
def body = msg.body // => request body as a string
def status = msg.status // => http status code of the response
def json = msg.json // => any JSON included in response body, as a data structure of lists and maps
def xml = msg.xml // => any XML included in response body, as a document tree structure
def data = msg.data // => either JSON or XML in response body (whichever is specified by content-type header in response)
//log.debug data.ison
//log.debug "Message Headers String "+headersAsString
//log.debug "Message Headers Map "+headerMap
//log.debug "Body "+body
//log.debug "Status "+status
//log.debug "JSON "+json
//log.debug "XML "+xml
//log.debug "Data "+data
if ( data.ison == true ) {
log.debug "TRUE"
sendEvent(name: "switch", value: "on", isStateChange: true, displayed: false)
if ( data.ison == false ) {
log.debug "FALSE"
sendEvent(name: "switch", value: "off", isStateChange: true, displayed: false)
// handle commands
def off() {
log.debug “Executing ‘off’”
toggleRelay “turn=off”
def on() {
log.debug “Executing ‘on’”
toggleRelay “turn=on”
def toggleRelay(action) {
sendHubCommand(new physicalgraph.device.HubAction(
method: “POST”,
path: “/relay/”+Relay,
body: action,
headers: [
HOST: getHostAddress(),
“Content-Type”: “application/x-www-form-urlencoded”
result
private getHostAddress() {
log.debug “Using IP: ip and PORT: 80 for device: {device.id}”
device.deviceNetworkId = convertIPtoHex(ip)+":"+convertPortToHex(8+Relay)
log.debug device.deviceNetworkId
return ip+":80"
private String convertIPtoHex(ipAddress) {
String hex = ipAddress.tokenize( ‘.’ ).collect { String.format( ‘%02x’, it.toInteger() ) }.join()
log.debug “IP address entered is $ipAddress and the converted hex code is $hex”
return hex
private String convertPortToHex(port) {
String hexport = port.toString().format( ‘%04x’, port.toInteger() )
log.debug hexport
return hexport
def updated() {
log.debug “updated()”
unschedule()
runEvery1Minute(“poll”)
poll()
def refresh() {
getStatus()
def poll() {
getStatus()
def getStatus() {
log.debug “Polling”
method: “GET”,
headers: [
def push() {
sendEvent(name: “switch”, value: “on”, isStateChange: true, displayed: false)
sendEvent(name: “switch”, value: “off”, isStateChange: true, displayed: false)
sendEvent(name: “momentary”, value: “pushed”, isStateChange: true)
