Hello,
I've been trying to get my Shelly 1PM Gen3 with temperature sensor / Addon working. The Shelly device is displayed via Cloud Integration and Matter, but not the addon / temperature. When I try to add the Shelly locally,to integrat the shelly by edge driver, the app can't find it during the scan. I've tried many network settings, but without success. Can anyone help?
If you have ST Hub you can try
Hello TapioX, I have try it but it does not work. I can add the shelly bei matter but then I am not able to change the driver because the driver is not shown. I have found now way to add the shelly local without matter, but I think that is the solution. I need somen who have a Iphone or desktop pc as I witch have integrated the shelly as i want. I hope to find the mistake. It is possible that the Iphone is the problem but I have no android devices.
The Shelly driver is Lan driver. You don’t change drivers. You install the driver on your hub and then you run Scan nearby. It should automatically find your Shelly device.
There is the Problem. If I run Scan nearby he does not find the Shelly device. I think i do something wrong, but what? Must the shelly at first integrated in the shelly app?
I don’t know. I have only used Shelly local web tool.
You can see temperature sensor 's value in Shelly App or Shelly web interface.
You have installed the driver on your hub and then after installation you have run Scan nearby.
I use MQTT communication to/from Shelly Devices
The device needs to be on your local network, so initially you will need to use the Shelly app to get it on your network.
Using Shelly local web tool is possible to set WiFi. For initial setup Shelly Devices create their own WiFi network. After setup it’s possible to disable Shelly Devices’ own WiFi network and continue using only router’s WiFi network.
I think I have found the problem with the edge driver. If only the Shelly Gen2/3 Device Driver V1.7 is installed the Smartthingsapp do not find the device. If the driver Shelly Gen2/3 Device Driver V1.7 and Shelly Device Driver V1.9 is installed, the shelly was found and it is possible to change the driver from V1.9 to V1.7.
I seem to have a similar issue with Shelly 1 Gen3 and ismartgate isg-wds contact sensor. In the app, all is fine and dandy, I see the correct. In SmartThings only the switch part shows without the contact sensor.
