I would like to create an automation that triggers after sunset to change the default dimmer switch levels. After sunset I really only want them going up to about 60% of max, I would then have them go back to 100% in the morning. Is this possible? Thanks.
I use a duplicate set of rules for all my buttons/switches (I only use smart bulbs)… One rule that only applies when eg. in Night mode = Turn on and set dimm level to 10%, and one rule that only applies to Home mode = Turn on and set dimm level to 70%
As you can create multiple modes, you could create two “Home modes”… One normal and one dimmed… And then make a rule that automatically change to “Home dimmed” at sunset, and vice versa…
Edit: Just realized that you can also do this based on time of day in the Smart lighting app…
Eg. a set of rules that applies only between 6 AM to 6 PM, and another set for the rest of the day…
Lots of options i guess…
