Hi all,
Just noticed this was happening. I have a few dimmers and on/off switches and in a few of my routines, I turn the lights on, set the dimmers to a specific level, and change the thermostat. What I noticed through the log is that whenever setLevel is run on a device that doesn’t have dimmer, it returns an error, making smartthings unable to change my thermostat level. The only solution I’ve run into thus far is that I either:
- Take off dimmer setLevel on my routine
- Take off on/off lights on routine and add as part of another routine
- Take off the thermostat and run on separate routine
…unless anyone has any suggestions? Here’s the log:
72232297-edf2-4175-aab4-468fb86a56e7 7:23:15 PM: trace getPhrases(), state.welcomeIssue = null
581c714a-1a90-4d9d-b128-38906c7877de 7:21:49 PM: debug 01
581c714a-1a90-4d9d-b128-38906c7877de 7:21:49 PM: trace read attr - raw: 94670A0019120049110100A4010000, dni: 9467, endpoint: 0A, cluster: 0019, size: 12, attrId: 4900, encoding: 11, value: 000001a40001
f11b553f-1525-4863-a818-ea1387398eb1 7:20:56 PM: debug updating TS
f11b553f-1525-4863-a818-ea1387398eb1 7:20:56 PM: debug event from: Loft Hallway Lights, value: 99, source: DEVICE, description: zw device: 14, command: 2603, payload: 63
5e5d75bd-15e8-413d-874e-e5de8a4129ac 7:20:52 PM: debug Parse returned Desk Lamp switch is on
5e5d75bd-15e8-413d-874e-e5de8a4129ac 7:20:52 PM: trace data: [1, 0]
5e5d75bd-15e8-413d-874e-e5de8a4129ac 7:20:52 PM: trace SmartShield(clusterId: 0x0006, command: 0x0b, data: [0x01, 0x00], destinationEndpoint: 0x01, direction: 0x01, isClusterSpecific: false, isManufacturerSpecific: false, manufacturerId: 0x0000, messageType: 0x00, number: null, options: 0x0140, profileId: 0x0104, senderShortId: 0x7bca, sourceEndpoint: 0x0a, text: null)
5e5d75bd-15e8-413d-874e-e5de8a4129ac 7:20:52 PM: trace catchall: 0104 0006 0A 01 0140 00 7BCA 00 00 0000 0B 01 0100
5e5d75bd-15e8-413d-874e-e5de8a4129ac 7:20:51 PM: trace data: [4, 0]
5e5d75bd-15e8-413d-874e-e5de8a4129ac 7:20:51 PM: trace SmartShield(clusterId: 0x0008, command: 0x0b, data: [0x04, 0x00], destinationEndpoint: 0x01, direction: 0x01, isClusterSpecific: false, isManufacturerSpecific: false, manufacturerId: 0x0000, messageType: 0x00, number: null, options: 0x0140, profileId: 0x0104, senderShortId: 0x7bca, sourceEndpoint: 0x0a, text: null)
5e5d75bd-15e8-413d-874e-e5de8a4129ac 7:20:51 PM: trace catchall: 0104 0008 0A 01 0140 00 7BCA 00 00 0000 0B 01 0400
581c714a-1a90-4d9d-b128-38906c7877de 7:20:51 PM: trace data: [4, 0]
581c714a-1a90-4d9d-b128-38906c7877de 7:20:51 PM: trace SmartShield(clusterId: 0x0008, command: 0x0b, data: [0x04, 0x00], destinationEndpoint: 0x01, direction: 0x01, isClusterSpecific: false, isManufacturerSpecific: false, manufacturerId: 0x0000, messageType: 0x00, number: null, options: 0x0140, profileId: 0x0104, senderShortId: 0x9467, sourceEndpoint: 0x0a, text: null)
581c714a-1a90-4d9d-b128-38906c7877de 7:20:51 PM: trace catchall: 0104 0008 0A 01 0140 00 9467 00 00 0000 0B 01 0400
**->[THIS LINE HERE] ->14b90add-1a33-4881-9b3a-f7d962a75e21 7:20:51 PM: error java.lang.IllegalArgumentException: Command 'setLevel' is not supported. Supported commands: [on, off, poll, refresh, indicatorWhenOn, indicatorWhenOff, indicatorNever] @ line 322**
14b90add-1a33-4881-9b3a-f7d962a75e21 7:20:50 PM: trace getSuffix(), index: null
14b90add-1a33-4881-9b3a-f7d962a75e21 7:20:50 PM: trace prefix(am'): I am
14b90add-1a33-4881-9b3a-f7d962a75e21 7:20:50 PM: trace settings: [thermostats:[Upstairs Thermostat], coolingSetpoint:72, newMode:Home, pushNotification:false, dimmerLevel:100%, onSwitches:[Bed Lamp, Desk Lamp, Loft Hallway Lights, Drive Way Lights, Front Porch Light]]
14b90add-1a33-4881-9b3a-f7d962a75e21 7:20:50 PM: debug HH execute(), newMode: Home
5e5d75bd-15e8-413d-874e-e5de8a4129ac 7:20:51 PM: trace setLevel(99)
581c714a-1a90-4d9d-b128-38906c7877de 7:20:51 PM: trace setLevel(99)
581c714a-1a90-4d9d-b128-38906c7877de 7:20:50 PM: debug Parse returned Bed La
