I am having trouble getting my servo to respond to alexa commands. it works fine if i go to the ip address, and serial monitor.
serial monitor also shows the commands from alexa are processing but no servo movement. i think I have something wrong on the digitalwrite command or something
PLEASE HELP
#include <ESP8266WiFi.h>
#include <DNSServer.h>
#include <ESP8266WebServer.h>
#include <WiFiManager.h>
#include <WiFiUdp.h>
#include <functional>
#include <Servo.h>
#include <WiFiClient.h>
#include <ESP8266mDNS.h>
ESP8266WebServer server(80);
Servo myservo;
int pos = 0;
int state = 0;
int prevstate = 0;
int dirc = 0;
int servoPin = D3; //CHANGE TO WHATEVER PIN YOUR USING
// Declare function prototypes
bool connectUDP();
void prepareIds();
void respondToSearch();
void startHttpServer();
// Change these to whatever you'd prefer:
String device_name = "servo controler"; // Name of device
bool debug = false; // If you want debug messages
bool squawk = true; // For on/off messages
// Some UDP / WeMo specific variables:
WiFiUDP UDP;
IPAddress ipMulti(239, 255, 255, 250);
unsigned int portMulti = 1900; // local port to listen on
ESP8266WebServer HTTP(80);
String serial; // Where we save the string of the UUID
String persistent_uuid; // Where we save some socket info with the UUID
// Buffer to save incoming packets:
char packetBuffer[UDP_TX_PACKET_MAX_SIZE];
void setup() {
pinMode(servoPin, OUTPUT);
delay(1000);
Serial.begin(9600);
delay(500);
Serial.println("Startup Sequence");
delay(500);
Serial.println();
Serial.print("Connecting to ");
// Set the UUIDs and socket information:
prepareIds();
// Get settings from WiFi Manager:
WiFiManager wifiManager;
//wifiManager.resetSettings(); // Uncomment this to test WiFi Manager function
wifiManager.autoConnect("Autocontrol");
// Wait til WiFi is connected properly:
int counter = 0;
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(".");
counter++;
Serial.println("Connected to WiFi");
Serial.println("IP address: "); Serial.println(WiFi.localIP());
// Connect to UDP:
bool udpConnected = connectUDP();
if (udpConnected){
startHttpServer(); // Start the HTTP Server
void loop() {
HTTP.handleClient();
delay(1);
// If there are packets, we parse them:
int packetSize = UDP.parsePacket();
if(packetSize) {
if (debug) {
Serial.println("");
Serial.print("Received packet of size ");
Serial.println(packetSize);
Serial.print("From ");
IPAddress remote = UDP.remoteIP();
for (int i =0; i < 4; i++) {
Serial.print(remote[i], DEC);
if (i < 3) {
Serial.print(".");
Serial.print(", port ");
Serial.println(UDP.remotePort());
int len = UDP.read(packetBuffer, 255);
if (len > 0) {
packetBuffer[len] = 0;
String request = packetBuffer;
if(request.indexOf('M-SEARCH') > 0) {
if(request.indexOf("urn:Belkin:device:**") > 0) {
if (debug) {
Serial.println("Responding to search request ...");
respondToSearch();
delay(10);
void prepareIds() {
uint32_t chipId = ESP.getChipId();
char uuid[64];
sprintf_P(uuid, PSTR("38323636-4558-4dda-9188-cda0e6%02x%02x%02x"),
(uint16_t) ((chipId >> 16) & 0xff),
(uint16_t) ((chipId >> 8) & 0xff),
(uint16_t) chipId & 0xff);
serial = String(uuid);
persistent_uuid = "Socket-1_0-" + serial;
bool connectUDP(){
boolean state = false;
Serial.println("Connecting to UDP");
if(UDP.beginMulticast(WiFi.localIP(), ipMulti, portMulti)) {
Serial.println("Connection successful");
state = true;
else{
Serial.println("Connection failed");
return state;
void servo_move() {
Serial.println("State Change. Rotating Servo");
if ( dirc == 180) {
myservo.attach(servoPin); // energize servo
delay(50);
for (pos = 0; pos <= 90; pos += 1) { // goes from 0 degrees to 90 degrees in steps of 1 degree CHANGE 90 TO MATCH ANGLE OF TILT DESIRED
myservo.write(pos); // tell servo to go to position in variable 'pos'
delay(30); // waits 30ms between each degree to slow rotation speed
delay(50);
myservo.detach(); // movement finished so detach servo to conserve power
else if (dirc == 0) {
delay(50);
for (pos = 90; pos >= 0; pos -= 1) { // goes from 90 degrees to 0 degrees in steps of 1 degree CHANGE 90 TO MIRROR ANGLE OF TILT DESIRED ABOVE
delay(50);
Serial.println("Returning to main loop");
return;
void startHttpServer() {
HTTP.on("/index.html", HTTP_GET, [](){
if (debug) {
Serial.println("Got Request index.html ...\n");
HTTP.send(200, "text/plain", "Hello World!");
HTTP.on("/upnp/control/basicevent1", HTTP_POST, []() {
if (debug) {
Serial.println("########## Responding to /upnp/control/basicevent1 ... ##########");
//for (int x=0; x <= HTTP.args(); x++) {
// Serial.println(HTTP.arg(x));
String request = HTTP.arg(0);
if (debug) {
Serial.print("request:");
Serial.println(request);
if(request.indexOf("<BinaryState>1</BinaryState>") > 0) {
if (squawk) {
Serial.println("Got open request");
digitalWrite(servoPin, HIGH);
if(request.indexOf("<BinaryState>0</BinaryState>") > 0) {
if (squawk) {
Serial.println("Got close request");
digitalWrite(servoPin, LOW);
HTTP.send(200, "text/plain", "");
HTTP.on("/eventservice.xml", HTTP_GET, [](){
if (debug) {
Serial.println(" ########## Responding to eventservice.xml ... ########\n");
String eventservice_xml = "<?scpd xmlns=\"urn:Belkin:service-1-0\"?>"
"<actionList>"
"<action>"
"<name>SetBinaryState</name>"
"<argumentList>"
"<argument>"
"<retval/>"
"<name>BinaryState</name>"
"<relatedStateVariable>BinaryState</relatedStateVariable>"
"<direction>in</direction>"
"</argument>"
"</argumentList>"
"<serviceStateTable>"
"<stateVariable sendEvents=\"yes\">"
"<dataType>Boolean</dataType>"
"<defaultValue>0</defaultValue>"
"</stateVariable>"
"<name>level</name>"
"<dataType>string</dataType>"
"</stateVariable>"
"</serviceStateTable>"
"</action>"
"</scpd>\r\n"
"\r\n";
HTTP.send(200, "text/plain", eventservice_xml.c_str());
HTTP.on("/setup.xml", HTTP_GET, [](){
if (debug) {
Serial.println(" ########## Responding to setup.xml ... ########\n");
IPAddress localIP = WiFi.localIP();
char s[16];
sprintf(s, "%d.%d.%d.%d", localIP[0], localIP[1], localIP[2], localIP[3]);
String setup_xml = "<?xml version=\"1.0\"?>"
"<root>"
"<device>"
"<deviceType>urn:Belkin:device:controllee:1</deviceType>"
"<friendlyName>"+ device_name +"</friendlyName>"
"<manufacturer>Belkin International Inc.</manufacturer>"
"<modelName>Emulated Socket</modelName>"
"<modelNumber>3.1415</modelNumber>"
"<UDN>uuid:"+ persistent_uuid +"</UDN>"
"<serialNumber>221517K0101769</serialNumber>"
"<binaryState>0</binaryState>"
"<serviceList>"
"<service>"
"<serviceType>urn:Belkin:service:basicevent:1</serviceType>"
"<serviceId>urn:Belkin:serviceId:basicevent1</serviceId>"
"<controlURL>/upnp/control/basicevent1</controlURL>"
"<eventSubURL>/upnp/event/basicevent1</eventSubURL>"
"<SCPDURL>/eventservice.xml</SCPDURL>"
"</service>"
"</serviceList>"
"</device>"
"</root>\r\n"
"\r\n";
HTTP.send(200, "text/xml", setup_xml.c_str());
if (debug) {
Serial.print("Sending :");
Serial.println(setup_xml);
HTTP.begin();
if (debug) {
Serial.println("HTTP Server started ..");
void respondToSearch() {
if (debug) {
Serial.println("");
Serial.print("Sending response to ");
Serial.println(UDP.remoteIP());
Serial.print("Port : ");
char s[16];
String response =
"HTTP/1.1 200 OK\r\n"
"CACHE-CONTROL: max-age=86400\r\n"
"DATE: Tue, 14 Dec 2016 02:30:00 GMT\r\n"
"EXT:\r\n"
"LOCATION: http://" + String(s) + ":80/setup.xml\r\n"
"OPT: \"http://schemas.upnp.org/upnp/1/0/\"; ns=01\r\n"
"01-NLS: b9200ebb-736d-4b93-bf03-835149d13983\r\n"
"SERVER: Unspecified, UPnP/1.0, Unspecified\r\n"
"ST: urn:Belkin:device:**\r\n"
"USN: uuid:" + persistent_uuid + "::urn:Belkin:device:**\r\n"
"X-User-Agent: redsonic\r\n\r\n";
UDP.beginPacket(UDP.remoteIP(), UDP.remotePort());
UDP.write(response.c_str());
UDP.endPacket();
if (debug) {
Serial.println("Response sent !");
void configModeCallback(WiFiManager *myWiFiManager) {
Serial.println("Entered config mode");
Serial.println("Soft AP's IP Address:");
Serial.println(WiFi.softAPIP());
Serial.println("WiFi Manager: Please connect to AP:");
Serial.println(myWiFiManager->getConfigPortalSSID());
Serial.println("To setup WiFi Configuration");
