Hi
I need some help controlling a Servo in SmartThings?
Servo starts at zero and then when on button is pressed in SmartThings app Servo will turn to 180.
Then when on button is pressed then Servo will turn to 0.
I’m use a WeMos D1 CH340 WiFi Arduino UNO R3 Development Board ESP8266.
ST_Anything_ESP8266WiFi loaded on it but but that is as far as I can get so far.
What I’m not understanding is how to make ST_Anything_ESP8266WiFi talk. To see if SmartThings and is if SmartThings sending commands back?
You will get the fastest and best response if you post in the author thread for the code you are using. The author is automatically notified when your post is added to the thread, and other people using the same code may also be able to help. In this case: ( this is a clickable link)
