Will these work with Alexa with the smartthings hub?
2700k is my friend. I can just bare 3000k but those 5000k (Daylight) bulbs seems so unnatural to meā¦Itās like the light of a thousand sunsā¦To each its own. ![]()
They work fine for me in that setup, paired quickly.
Like @Mundar, I go the other way with white color. There are only a couple of fixtures in my house that are not bright white. Everything else is either ~5000k or RGB. I might just put them in one of my kidsā ceiling fan. Each of those has 4 bulbs, soā¦
Anything that works with ST will work with Alexa through ST. Alexa just sees it as a switch, dimmer, etc.
Hey all. I picked up a couple of these bulbs and I canāt get them to pair with my ST hub. The bulbs flash as is they are pairing but nothing shows up in the app. Any ideas? Iāve googled the heck out of this and canāt find anything.
All mine have just paired, both on V1 and V2 hubs. Just turn the bulb on wait for the flashes to let you know itās in pairing mode, hit add a new thing on ST and wait for the light to flash again and they pop up in ST.
Iāve got kinda the same problem. Bought the 4 pack.
First bulb blinked 3 times but never would pair with ST. Tried a 2nd bulb and it paired right up. Tried the 3rd bulb and it also paired right up. Tried the 1st one again. Did the on/off for 10 times but it never blinked. Tried this several times, no luck.
I think I might have a different problem. Just tried to pair 2 new Keen Smart Vents and I get the same thing. The pairing light flashes as if itās paired and itās not showing up in my list of things. I realize this takes me off topic, but not finding anyone talking about this issue. If anyone has any ideas, Iām all ears. I have a pair of Philips bulbs paired already as well as Arlo and a PEQ motion sensor.
