Really hoping someone can help me out on what I need to do to issue secure commands. I know it’s connected secure from the raw description in the IDE.
Below is a snippet of code I threw in just to trigger some things. The first result << line is line 107.
preferences {
input "checkConfig", "bool", title: "Check Parms", description: "On/Off", required: false, defaultValue: false
def updated() {
def result = []
result << response(secure(zwave.configurationV1.configurationSet(parameterNumber: 1, size: 1, configurationValue: 0)))
result << "delay 1000"
result << response(secure(zwave.configurationV1.configurationGet(parameterNumber: 1).format()))
return result
And my secure routine is standard:
private secure(physicalgraph.zwave.Command cmd) {
zwave.securityV1.securityMessageEncapsulation().encapsulate(cmd).format()
The parameter just takes 0 or 1, so it should work like this. But, when I try it as above, I get this message:
error org.codehaus.groovy.runtime.typehandling.GroovyCastException: Cannot cast object ‘0’ with class ‘java.lang.Integer’ to class ‘java.util.List’ @ line 107
If I use the preferences value, like below, it just gets ignored but I get no error.
result << response(secure(zwave.configurationV1.configurationSet(parameterNumber: 1, size: 1, configurationValue: [checkConfig == true ? 1 : 0])))
To make matters worse, the simple get command I’m trying to isue gives me this message:
error groovy.lang.MissingMethodException: No signature of method: script148451431164587999064.secure() is applicable for argument types: (java.lang.String) values: [700501]
Possible solutions: remove(java.lang.String), section(java.lang.String), state(java.lang.String), section(), every(), render(java.util.Map) @ line 109
For the life of me I can’t figure out or understand why I can’t just get this basic part to work.
