Schlage Keypad deadbolt, keypad lock goodbye vs manual lock stay
I am trying to figure out how to setup either a CORE Piston or Routine to fire appropriate Goodbye routine if the keypad is used to lock the deadbolt from the outside versus if the lock is manually locked from inside and not running goodbye. I have the latest lock manager and I see that the activity feed is logging the difference. I have tried to search for the answer with no luck in the forums. I just must not be using the right search words. Any help on pointing me in the right direction would be greatly appreciated! Thanks in advance.
I couldn’t do it with Core, but I could do it with the @RBoy universal lock dth and @RBoy “Lock multi user code management with notifications and automatic relock” smartapp. It allows you to set up actions for the various un/locking scenarios.
So $35 and I’m set?
I’m not sure if there is another way, but I’ve been satisified with the $35 i spent, and have used a few of the other dths and smartapps he’s developed besides the lock stuff.
