I for one would love to be able to set color for my osram lightify and gardenspot.
Iâm working on color right now. Next major feature comingâŚ
Hey - found a bug / issueâŚ
When smartthings crashes and Iâm editing a rule (which had now happened twice within a minute) you canât access that rule anymore! Iâve pinpointed the issue (which I assume is a smartthings not rule machine issue) to when wifi disappears (even if mobile data is on and available). So now I have a couple of rules that are broken & I canât remove them! The error I get when I try and go into one is the usual: you are not authorised to access the requested information.
Any way around this or more importantly, any way I you can make it so I can delete the corrupted rules and start them again?!
Cheers - loving rule machine (minus this!)
Feature request: addition to motion sensor: ability to only have that triggered if itâs inactive for âxâ minutes rather than as soon as there is no inactivity.
Only solution at this time is to completely uninstall Rule Machine and start over
Nooooooooooooo my entire smartthings set up crumbles to the ground without it! Hope something can be done medium-term
Unfortunately, not at the moment. The only way to get rid of the bastards (HaHa) is to uninstall Rule Machine and start over. Since this seems to happening with some frequency, perhaps I will see if some other mechanism could be created to get rid of malformed rules.
Yeah. it happened to me yesterday⌠rebuilt all of my rules and then 2 hours later, it happened again!
@primarypete
Unruly (pun intended) children can be deleted via the IDE.
My Locations
List Smart Apps (click edit)
Find Rule Machine, then the corrupted rule.
Click the uninstall link.
If that doesnât work, post the debug logs when trying to access the rule in question.
âyou are not authorised to access the requested informationâ is âusuallyâ a java null errorâŚ
SUPERB @Mike_Maxwell !!!
Works a dream through the IDE. Cheers @bravenel too. Itâs you guys that are making Smartthings work for us mere mortals with epic smartapps and decent support! Keep up the OUTSTANDING work
New release today:
Small request, the thermostat text is different between the actions if true and actions if false. No big deal, just an FYI.
Both should be âset these thermostatsâ IMHO.
This is still awesome. I can replace so much with one brilliant app.
One other suggestion with something so awesome is I think you may want to split into beta and released for testing, because I can see a LOT of people becoming VERY dependent on this app and reliability. Itâs brilliant.
This has been fixed in 1.1.13.
would love to see dates/ calendar implementation. (in addition to the already present days of the week, time specific events)
use cases:
- for the 2nd week of may, Iâm on vacation, so pause these tasks or add these tasksâŚ
- or schedule this task repeat every 2 hr,wk, month, for 3 instances or upto this date.
- iâm at home only this week on tuesday / wed (not a weekly recurrence), so over-ride the thermostat scheduled program. otherwise resume regular scheduled program.
Those really sound like the kind of things that modes are good for. Vacation mode, for example. You can have rules that only run during Vacation mode, and other rules that donât. Etc. I know some people use logic to kick from Away to Vacation, such as being absent a certain amount of time. But, I go on vacation rarely enough that doing it manually is better for me.
Assuming ST can get their backsides in gear to mix the mode restriction issuesâŚ
Set color temperature based on the condition of a switch turning on (like a bulb).
Iâm working on it. I donât have any color bulbs. I got one today and tried to connect it, no luck. Back to BestBuy tomorrow. I will not release the code without testing it.
Thanks @bravenel. The bulbs I have are the OSRAM Tune-able White Bulbs (2700-6500k). Theyâre on sale at BB right now, and also available at Home Depot.
Thanks, Iâll grab one of those. I may get an Osram strip too.
