I would delete the device and start over.
1st add @milandjurovic71 “Z-Wave sensor Ring” Edge Driver and then try to re-pair the sensor using the new Edge Drivers. Do not change anything in the IDE after you re-pair it. It should show up as Placeholder in the IDE which is what you want to see.
