Ring integration
Hi everyone. I am planning to purchase ring door sensors 2nd generation and fire alarm listener, maybe somebodynhave experience in how is it simple or too complicated? Any advice appriciated
Which smartthings/Aeotec hub do you have?
As long as your ST compatible hub supports Zwave on the same frequency as the sensors, you can just add the sensors directly as zwave devices and they are quite popular for that purpose.
I’m not sure whether the acoustic listener is compatible or not. Hopefully if somebody does know they will post.
You probably already know this, but just to be sure, you cannot use the devices with both a ring security hub and a SmartThings compatible hub at the same time. It’s one or the other.
I am using v2 hub. It has z-wave. Tha ks for reply
