Reverse Direction Of Zigbee Blinds
Is It possible to reverse the direction of blinds in Smartthings?
I am using QMotion blinds with the ‘zigbee window covering’ Device Type Handler. However for some reason, up is down and down is up. Is there a way of reversing the commands that it sends or some sort of work around?
When using the Zigbee Dimmer as the DTH, the direction is correct AKA brighter bulb = More open blind. Is it possible to modify the DTH?
TIA!
Came across this post via Google search; adding this for posterity. This smartthings edge driver from @Mariano_Colmenarejo fixed the blinds direction for me.
@Mariano_Colmenarejo nailed it. His process and driver update fixes these issues
