Hi,
I decided to move forward with automating my Liftmaster Garage door by connecting it to the ST hub. I currently have the unit controlled by Multi Function Control panel similar to this one - https://www.amazon.com/Liftmaster-41A5273-1-Multi-Function-Control-Panel/dp/B000F5KF1O/ref=pd_ybh_a_1?_encoding=UTF8&psc=1&refRID=45Z3MVZ9X7YG0Y7XWE1Y
Initially, I thought about using low voltage Z-Wave relay - https://www.thesmartesthouse.com/products/qubino-z-wave-plus-flush-1d-relay-module-zmnhnd3
BUT It seems like I’ll lose some of this panel functionality if I’ll install the Z-wave relay instead of it - Not to say I’ll be losing the actual physical switch inside the garage.
Anyone did any similar swap and can share any ideas on how to do it without losing the functionality.
I could not find any similar project anywhere…
