[REMOVED] Nest Manager 3.1
I just got nest protect. I cant see it in already configured nest manager. How do it add it in smartthings?
You can see updates by looking at the Recently ā€œtabā€ when you open the device in the mobile app. It should show you data updates as data changing
Launch nest manager, and it should see the new protect (assuming you added it to your nest account during its setup/install), select it and hit done.
Ensure you followed install instructions and the device type handlers (dth) are installed in SmartThings.
Thanks. I found it. Thank you!
Is it possible to use motion sensor/water leak sensor or any other sensor
which has temperature detection as remote sensor?
the remote sensor automation lets you select alternate temperature sensors to use for the zone.
Tony will have a new release later this week, so you can try it now, or get the new release friday/this weekend
Eric as you mentioned I am looking in the recently tab of the device in the mobile app i donā€™t see any updatesā€¦ the last update was when the device was first discoveredā€¦ hence not even sure if its working
Tonesto7 response was "Thatā€™s normalā€¦ The protects donā€™t check in very often. Now if 12hrs go by and no change than something might be wrong:
its been over approx 2 days an no updates are showing no matter how many times I do the refresh.
You next choice is the PM tony and I with IDE logs, so we can see what the IDE logs say.
Yeah we will need to see so logs from the IDE
https://graph.api.smartthings.com/ide/logs
IDE logs sent to you and Eric
Hi Anthony,
Thanks so much for this awesome app. This is a massive thread, so I apologize if this info is already in here. Can you point me to a link on how to update the app? Mine is still 2.5.10. I am having issues seeing my Nest Protect in Smarthtings, (your smart app sees it).
Before I started troubleshooting, I wanted to make sure I have the latest version.
Thanks.
Go to the wiki listed in the 4.0 thread. Gives you all the instructions.
Thank you for that. I was able to update and install the device, but I am still having a weird status. Please see the attached.
Thanks.
I noticed my automations werenā€™t working this weekend. It turns out they havenā€™t been working for a couple of weeks. I had to uninstall the automations, the associated SmartApps and Nest Manager. Once I reinstalled everything, all worked as expected. Is this normally needed when upgrading to a new version of Nest Manager? :unamused:
Reinstall is Not usually required. This upgrade required all existing automations be removed before upgrading because it was such a drastic change to the core code.
Iā€™m in southern part of Ypsi too - we should set up a S. Michigan group. Iā€™m just getting into it and starting to make my house slowly functionally smart. Itā€™s an interesting, albeit slow, project thus far.
