Just removing the fade rate is not enough. if the device is not rated for use with the motor, do not use it with a motor. The startup physics are different and you can burn out the dimmer, the motor, or both.
Unfortunately, you will just need to get some pocket sockets that are rated for use with motors. This is not something you can change through parameter configuration.
