I am working on a profile for a remote control. There are no custom vids or capabilities. The buttons will not update their status when I emit events from them. They remain in standby mode. The device will also not send an event for pull-to-refresh. I have seen other refresh issues, but those were with custom vids, this is not.
This is being tested on Android. Here is the profile:
You’ll need to set the state_change flag to true on the button events otherwise consecutive button presses of the same type won’t work. They may show up in the app UI but they won’t propagate any further to automations of the device history.
The standby status is purely an invention of the app. You should see it change but it’ll always change back.
Found it. That’s a good hint and probably would have bit me at some point, so thanks. Unfortunately, the state in the app still won’t change away from standby.
I tried to replicate this without success. I don’t know if it’s because the app was updated. In this case, I use the capability Switch to trigger the event:
Have you checked the behavior with the new version?
Next, I’ll check with your config. Update: I couldn’t replicate it using your profile and supportedValues defined
