Hi members,
I’m new to this world of Home Automation.
I just bought a Remotec zwave dry contact switch, i connect it, after allot of tries, i figured out how to switch it to momentary switch.
My gate door is very simple, only 2 wires, when they touch together, both gate doors will open, when you touch them together back they closes.
After I changed the switch to momentary switch, i started working perfectly, but only 1 gate door opens and close.
If both gates are close, when i press the switch, both opens, but after that, the left one stays open, and the right one close and opens perfectly.
I think it has something to do with the script, again if i remove the wires, put them together both gates works, but only with the switch, only 1 opens.
i think this needs to work like a bell switch, when you press it, it needs to open, and release, when you press it back it needs to contact and close the gate.
Here is my script i copied:
I don’t know if i’m missing something.
Many thanks, hope someone can help me out.
Ryan
Copyright 2015 SmartThings
Licensed under the Apache License, Version 2.0 (the “License”); you may not use this file except
in compliance with the License. You may obtain a copy of the License at:
http://www.apache.org/licenses/LICENSE-2.0 -
Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
on an “AS IS” BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
for the specific language governing permissions and limitations under the License.
SmartSense Virtual Momentary Contact Switch
Author: SmartThings
Date: 2013-03-07
metadata {
definition (name: “Z-Wave Virtual Momentary Contact Switch”, namespace: “smartthings”, author: “SmartThings”, ocfDeviceType: “x.com.st.d.sensor.contact”) {
capability "Actuator"
capability "Switch"
capability "Refresh"
capability "Momentary"
capability "Sensor"
capability “Relay Switch”
}// simulator metadata
simulator {
status “on”: "command: 2003, payload: FF"
status “off”: “command: 2003, payload: 00”// reply messages reply "2001FF,2502,delay 2000,200100,2502": "command: 2503, payload: FF" reply "200100,2502": "command: 2503, payload: 00"}
// tile definitions
tiles {
standardTile(“switch”, “device.switch”, width: 2, height: 2, canChangeIcon: true) {
state “off”, label: ‘${name}’, action: “momentary.push”, icon: “st.switches.switch.off”, backgroundColor: "#ffffff"
state “on”, label: ‘${name}’, action: “switch.off”, icon: “st.switches.switch.on”, backgroundColor: “#00a0dc”
standardTile(“refresh”, “device.switch”, inactiveLabel: false, decoration: “flat”) {
state “default”, label:’’, action:“refresh.refresh”, icon:“st.secondary.refresh”
}main "switch" details(["switch","refresh"])}
def result = null
def cmd = zwave.parse(description, [0x20: 1])
if (cmd) {
result = createEvent(zwaveEvent(cmd))
log.debug "Parse returned ${result?.descriptionText}"
return result
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicReport cmd) {
[name: “switch”, value: cmd.value ? “on” : “off”, type: “physical”]
def zwaveEvent(physicalgraph.zwave.commands.switchbinaryv1.SwitchBinaryReport cmd) {
[name: “switch”, value: cmd.value ? “on” : “off”, type: “digital”]
def zwaveEvent(physicalgraph.zwave.commands.manufacturerspecificv2.ManufacturerSpecificReport cmd) {
if (state.manufacturer != cmd.manufacturerName) {
updateDataValue(“manufacturer”, cmd.manufacturerName)
final relays = [
[manufacturerId:0x0113, productTypeId: 0x5246, productId: 0x3133, productName: "Evolve LFM-20"],
[manufacturerId:0x5254, productTypeId: 0x8000, productId: 0x0002, productName: "Remotec ZFM-80"]
def productName = null
for (it in relays) {
if (it.manufacturerId == cmd.manufacturerId && it.productTypeId == cmd.productTypeId && it.productId == cmd.productId) {
productName = it.productName
break
if (productName) {
log.debug "Relay found: $productName"
updateDataValue("productName", productName)
[name: "manufacturer", value: cmd.manufacturerName]
// Handles all Z-Wave commands we aren’t interested in
def push() {
def cmds = [
zwave.basicV1.basicSet(value: 0xFF).format(),
zwave.switchBinaryV1.switchBinaryGet().format(),
“delay 3000”,
zwave.basicV1.basicSet(value: 0x00).format(),
def on() {
push()
def off() {
def refresh() {
delayBetween([
zwave.manufacturerSpecificV1.manufacturerSpecificGet().format()
