Remote switch control
I have a ge toggle switch in an outdoor enclosure that controls my grill lights. It works fine from there manually, and fine from the app as well as my echo. Is there any device I can use to mount near the door to make a manual switch that can also control it. Keep in mind I can’t wire it into the circuit as it’s a line off the pool fuse box away from the house.
Is the area where you’ll put it covered?
This is a quick and easy option
http://www.lowes.com/pd_690401-41277-3460-L_1z0v12i__?productId=999925306&pl=1
Here’s a thread with the device type and discussion on using it
I want to mount it inside so that might be a good solution.
