Hello,
I am working on a project where I will need to simultaneously record the power consumption of some electrical equipment installed at several locations across the UK and this remotely. I need to be able to go back in time and see the power consumption for the last say 7 days with a time resolution of at least one per hour.
My understanding is that this could be possible with a low budget by using a TP-link HS110 smart plug and a SmartThing hub but I a new to ST and I am not quite sure where to start. I have been told that the programmed granularity in the smart plug driver is 1 minute for current power. What would be a good way to log this into a spreadsheet?
Thank you for your help.
Possible I’d check out ifftt see if there is a direct tplink or smartthings to spreadsheet feed
See the following thread for various options:
