If any brave advanced users have this device and are interested in testing a locally executing Edge Driver for it let me know and I’ll send you the invitation to my Zooz Channel once I’ve published it…
Those devices are at the top of my To Do list, but I need to make sure that users don’t run into any issues with the ZSE41 and ZSE42 drivers before attempting something more complex.
Received the XS water sensor today. Work just as well as my SmartThings water sensor. At first I tried the generic Zwave water sensor but that didn’t work. Had to use the device handler above. @krlaframboise I’m interested in the Edge Driver. Let me know what I need to do.
It will all depend on the amount of daily triggers and distance from the hub (if the communication is direct or indirect) - we estimate 8-12 months of battery life here.
I recently purchased several of these, deployed the device handler, and attached the devices. SmartThings shows them as connected but there is no logic associated with the device in SmartThings other than “connected”. The bridge between the device handler and the attached zse42 sensor doesn’t appear to be there in order to make it functional.
Has anyone else ran across this or have any suggestions on how to get these working?
-Brent
Solved: The last step I missed is assigning the handler to the device itself. Click on the device, edit the type to match the new device handler and you’re in business. I hope this helps someone else down the road.
