[RELEASE] Zigbee Live Map – see your Zigbee mesh, RSSI/LQI and ghost devices (no extra hardware)
Hi all :waving_hand:
SmartThings has never given us a real view of the Zigbee mesh – the old IDE route snapshot is gone, and the usual answer is “add an XBee / second coordinator”. So I built a free browser tool that shows it using only your ST hub.
:link: Open the map: Zigbee Live Map
What you get
  • :antenna_bars: Signal map – RSSI and LQI for every Zigbee device, refreshed every minute
  • :spider_web: Mesh map – the real topology: who is routed through whom, LQI per link, parent/child vs neighbor links
  • :clipboard: Mesh table – best and weakest link per device, weakest first
  • :ghost: Ghost devices – devices deleted from the app but still joined to the mesh, with a button to ask their parent router to drop them
  • :1234: Neighbor count also shown on the device page in the app
What you DON’T need
  • :prohibited: No second hub, XBee or Zigbee dongle
  • :prohibited: No PC – works on your phone too
  • :prohibited: Nothing to install
  • :prohibited: No Home Assistant
:white_check_mark: Just a browser and the ST hub you already have.
How to start
  1. Create a Personal Access Token at SmartThings. Add a little smartness to your things. with Devices → List all devices + See all devices (add Control all devices if you want ghost removal).
  2. Paste it into the page. The token stays in your browser and is sent only to api.smartthings.com. New tokens expire after 24h.
The Signal map works with any driver that reports LQI/RSSI (mine, Mariano’s, YG’s…).
Getting the full Mesh view
The Mesh tab is built from neighbor tables reported by routers (plugs, switches, bulbs, repeaters). Only drivers that include the neighbor module can report them:
  1. Join my channel: SmartThings. Add a little smartness to your things.
  2. Install the drivers you need:
    • Zigbee Switch SD
    • Zigbee Switch Power SD
    • Zigbee Multi Switch and Child SD
    • Zigbee Multi Switch Light Curtain SD
    • Zigbee Range Extender SD
    • Zigbee Window Treatment SD
    • Zigbee Thing SD
  3. Switch each router to its SD driver (device → ⋮ → Driver). :warning: Device preferences reset to defaults.
  4. Within ~15 minutes the router appears with a white outline and reports all its neighbors.
:battery: Battery devices don’t need switching – they show up automatically through the router they’re attached to.
How it works (for the curious)
  • The driver sends a standard ZDO Mgmt_Lqi_req (0x0031) to each router every 15 minutes and parses the Mgmt_Lqi_rsp (0x8031) neighbor table (paged, so large tables work).
  • It’s sent with the stock ST Lua libs – the Mgmt_Bind_req body has the same 1-byte payload, sent on cluster 0x0031.
  • The table is published as a custom capability; the page matches neighbors to your devices by EUI64 and draws a force-directed graph.
  • Ghost removal sends a standard Mgmt_Leave_req (0x0034) to the parent router and to the ghost. Tuya routers accepted it in my tests; Aqara plugs reply 0xF0 (not supported) – those clear only after a power cycle.
  • Everything runs client-side in your browser, no server in between.
Credits
Several of the SD drivers are forks of @Mariano_Colmenarejo’s excellent Mc drivers, with the neighbor module added – all credit to him for the base drivers :folded_hands:
Built with the help of AI (Claude).
:floppy_disk: Source code: GitHub - dotanshai/SmartThings: My SmartThing Deivce Handler · GitHub
:hot_beverage: If you find it useful: https://buymeacoffee.com/dotan_shai
Feedback, bugs and fingerprint requests welcome below :slightly_smiling_face:
Very nice thank you
I set this up the Signal map works but the mesh map doesn’t work. I get an error:
“No device reports a zigbee table yet. The mesh view needs edge drivers that publish a neighbors capability”
Thanks for trying it, @Paul_Oliver :folded_hands:
That message means none of your routers is running a driver with the neighbor module yet. The Signal map works with any driver, but the Mesh map only gets data from the SD drivers in my channel.
To get it working:
  1. Join the channel: SmartThings. Add a little smartness to your things.
  2. Install the matching SD driver(s) on your hub (Zigbee Switch SD, Switch Power SD, Range Extender SD, Multi Switch and Child SD, etc.)
  3. Switch at least one mains-powered device (plug, switch, bulb, repeater) to that driver: device → ⋮ → Driver → select the SD version
  4. Wait ~1–15 minutes, then press Refresh in the map
A single router is enough to see something – it reports all the devices around it, including ones on other drivers.
If you’ve already switched a device and it still shows nothing, could you tell me:
  • which device and which SD driver it’s on
  • whether it shows a “Zigbee neighbors” value on its device page in the app
And if none of your routers match my drivers’ fingerprints, post the manufacturer/model and I’ll add them.
Ok, That fixed that.
New problem. I have 2 hubs at this location a v2 (main building) and a ST Station (out building). They are NOT in a group. But the mesh only shows 1 hub with both systems connected to it.
Still useful. Thanks for sharing.
Thanks @Paul_Oliver , great catch! Each hub runs its own separate Zigbee network, but the map was drawing both coordinators as one “HUB”. I just pushed a fix: when a location has more than one hub, a hub selector appears next to the location selector, and “All hubs” shows both meshes side by side with each hub’s name. Hard-refresh the page (Ctrl+F5) to get the new version. Let me know how it looks!
Thanks, that cleaned up the mesh display nicely.
Thanks @ PerYourHealth share a great idea clean mesh display
