[RELEASE] Schlage Connect Lock Alarm Mode and Sensitivity Change and Monitor (BE469)
Manage and configure the built in Tamper Sensor and Siren/Alarm on the Schlage Locks
This app requires the use of the Universal Enhanced Z-Wave Lock with Alarms device handler.
Use this app to configure and manage Z-Wave Schlage locks that have a built in tamper sensor and a 90dB siren/alarm. The lock sensor can detect when someone is touching or tampering with the door which triggers the built in alarm and sends a notification through the custom device handler.
See Key Features for a full list of options available in the app.
Lock models with built in sensor/sirens (newer models will be automatically supported):
SCREENSHOTS
KEY FEATURES:
  • Configure the lock alarm mode
    • Off - Sensor and siren are disabled
    • Alert - When someone touches the door, the lock beeps to alert that someone is at the door (it does not send a notification over Z-Wave)
    • Tamper - When someone tries to tamper with the lock, the 90dB built in siren is triggered and a notification is sent to SmartThings
    • Forced - When someone tried to break down the door, the 90dB built in siren is triggered and a notification is sent to SmartThings
  • Set the sensitivity for each lock alarm mode
    • Lowest
    • Low
    • Medium
    • High
    • Highest
  • Customize alarm mode and sensitivity for each
    • Hub Mode
    • Classic SHM state
    • Routine (when run)
    • Lock state
  • Monitor when the built in Siren is triggered and take actions
    • Trigger a secondary Siren/Alarm
    • Turn on lights/switches
    • Send SMS (multiple numbers)
    • Send Push notification
  • Restrict monitoring of built in Siren/action based on Hub modes
  • Automatic app and device handler update notifications
INSTALLATION INSTRUCTIONS
You can find the installation instructions here
NOTES
  • Schlage locks don’t allow external control (trigger or turn off) of the built in alarms
  • When in Alert mode, a notification is not sent to the SmartThings hub and Siren only beeps
  • This app requires the use of the Universal Enhanced Z-Wave Lock with Alarms device handler.
  • ZigBee Schlage locks do not support the built in Siren/Sensor
Refer to our facebook page http://www.facebook.com/RBoySTApps to get the latest news and updates.
You can also check out the following lock management and security apps
© RBoy Apps
Schlage Lock Alarm Mode and Sensitivity Change and Monitor
Current version - 02.02.01
