@frazered@Mike_McD Let me know how you get on with Neato Device Handler v1.3. This adds compatibility with firmware 3.x which has slightly different commands from the older Botvac Connected models.
I installed the new v1.3 DH but seem to have the same issues 1) Robot serial secret error message, 2) Pressing the main clean tile does nothing and 3) Many values including battery level not showing or not showing correct values.
Note: I updated the v1.3 DH code in the IDE and deleted the robot and readded it with the connect (app) to refresh the new DH.
They finally updated my account to let me create smartapps but when I tried to paste in the code from Github I got the following error.
I finally got the app installed and the open auth set up so I can sign in but I can’t find the device handler in your github repository
These are all the files which are there now:
hive-connect.src v2.6
light-switch-force-sync.src
mihome-connect.src
neato-connect.src v1.1.6
ovo-energy-connect.src
parent/auto-mode-for-thermostats.src
thermostatmodeautomation/thermostat-mode-automation.src v1.4 -
warmup-connect.src
I can set up the app and authorize it but since I’m missing the device handler I get an error when trying to complete the setup. Was it pulled down for updataing or can you please point me to where the handler is?
Ignore all previous comments, I finally RTFM and got everything working. Really, what fun is tinkering if you just read the directions? This is so much better than the Neato native app as far as the info I get on each of the bots.
One question/suggestion I have three botvacs (multiple story home) and each one needs to run on a different schedule (the one for the bedrooms runs during the day, the one in the common areas run overnight etc) but it seems that a smart schedule applies to all the bots equally. Is there a way to have different smart schedules for each bot?
I wanted to share my experience on the installation… I used the same installation method from the C.o.R.E (Piston) app to install this app. Might be easier…?? Perhaps allow for easier updates as the Dev pushes them?
This part you will need to search for the correct src pkg and select only that one. (alyc100/SmartThingsPublic/blob/master/smartapps/alyc100/neato-connect.src/neato-connect.groovy)
And the Device Handler is like similar:
Select this item:
(alyc100/SmartThingsPublic/blob/master/devicetypes/alyc100/neato-botvac-connected-series.src/neato-botvac-connected-series.groovy)
At this point you should have a published SmartApp and Device Handler… I continued on with the original instructions to install the device in smarthings.
UPDATE: When the last code update was pushed, the code turned blue in the IDE, signifying there were updates available. Clicking the magnifying glass I was to copy to local, save, and republish.
I’ve installed it in my botvacs, I have 3 on different floors. Did one at first and after a day everything was working fine so I updated the others. I see no issues with the smartapp. The updated firmware gives better error info, such as clean my sensor instead of just ‘error 3000’ and a cleaning map but the functionality seems the same.
I’ll see if the updated error messages show in the app, might take an update but I don’t ever expect to see the cleaning map to show since it’s not something which could work in a tile.
I don’t think so, even the native app won’t do that.
To restrict the bot to certain areas you have to put down magnetic strips which act as boundaries for the bot. It’s not something that any app can control ‘yet’ (IMO the virtual map which is now created may give some options to do that in the future)
Wondering… Does anyone that is using the Neato Botvac also use SmartTiles? If so, do you know if there is a tile that exists to integrate it into SmartTiles? All I see is a switch.
