If there is an error it will show up in red. Otherwise the platform is timing out. If it doesn’t start working by tomorrow I would report it to Dev avocate Tim or Aaron to see why your instance is timing out
@slagle and or @Aaron could you have a look at this?
Like stated in the four last post.
It seems I get no execution from this smart app when i unlock my door lock.
It have worked 3 times in total, but for most times it does not work.
I have a core piston sending med an sms bound to events from the lock, and this works.
@rboy suspects its a timeout in the plattform, but there is no mentions of problems on the status.smartthings.com
Could you have a look into this?
This is my last step in automating locks and alarms.
So to confirm, we’re also seeing the same issue here starting this afternoon. The routines being executed from the SmartApp are timing out @slagle @Aaron and the routines don’t finish their configured actions
@einars since this is a “common” issue with ST from time to time, we’ve written a SmartApp that essentially acts like a backup routines. Thus is a routine fails this SmartApp kicks in and finishes up for it. So far I’ve found it 100% reliable, check it out:
This one seemes to work @RBoy
Think it could be “weight” of whats beeing executed? Would love to use your app as one stop solution.
##user Unlock/Lock Door Notifications and Actions - Version 3.2.1
- For multiple SMS/Text notifications now separate the numbers with a
;(the + can be used to send messages to international numbers) - Improved reliability to check for smart app and device handler updates and notify the user
Recommend use the [Universal Enhanced Z-Wave Lock] ([RELEASE] Universal Enhanced Z-Wave Lock Driver for Schlage, Yale, Kwikset, IDLock, Popp, Danalock, August Pro, Keywe, Philia, Samsung) device handler version 3.1.1 or newer for full SmartApp and automatic update notification functionality
After installing this code update, please (in this order):
1. Update the [Universal Enhanced Z-Wave Lock] ([RELEASE] Universal Enhanced Z-Wave Lock Driver for Schlage, Yale, Kwikset, IDLock, Popp, Danalock, August Pro, Keywe, Philia, Samsung) device handler to version 3.1.1 (required for automatic update notifications)
2. Open the lock device page on the ST phone app and click on Refresh
3. Open the SmartApp and click Next and then Done for the changes to take effect
###Don’t forget step 3 or the update notifications will not work
You’re website is down. And I just paid you the $35 lifetime subscription too!
Yes we are having an ISP issue. Sorry for the inconvenience. It will be
back up in a few hours.
The website is back up now. Thanks for your patience.
Thanks. The “I just paid you $35!!!” bit was supposed to mostly be a joke. Glad you’re back up.
Feature request.
Is it possible for you to to implement user notification when updated versions is available on your DH´s and SA´s?
Like SMS to me, og Push to me and not the whole family?
##user Unlock/Lock Door Notifications and Actions - Version 03.03.00
- Added support for reporting unknown users and running actions for master codes/users
- Added ability to NOT run door lock/unlock action when specified users are present or when in certain modes
- Reduce notifications verbosity for lock/unlock actions, enable detailed notifications to restore verbosity
Recommend use the [Universal Enhanced Z-Wave Lock] ([RELEASE] Universal Enhanced Z-Wave Lock Driver for Schlage, Yale, Kwikset, IDLock, Popp, Danalock, August Pro, Keywe, Philia, Samsung) device handler version 3.2.0 or newer for full SmartApp and automatic update notification functionality
Folks using the ZigBee device handler should update to the latest 1.3a Universal ZigBee device handler. This is to fix an issue with the lock reporting user 255 when using manual or remote locking/unlocking. Thanks for the quick turnaround @jhamstead
##user Unlock/Lock Door Notifications and Actions - Version 03.04.00
- Added support for selective use notifications only when users are not present
- Added ability to chime/ring a bell when the door is opened (with option to select modes)
- Improve quality of notifications and simplified user interface
I just purchased and installed 5.04, do I need to reset the lock prior to going to this version or can I just upgrade and re-publish?
If you’ve already got an older version of the SmartApp then just upgrade and republish.
If you’re installing it fresh for the first time, it would be better to clear all the codes from the lock/reset once before starting to use this SmartApp.
##user Unlock/Lock Door Notifications and Actions - Version 03.04.01
- Added support to report Master Code usage for supporting locks (e.g. Yale, IDLock etc)
Recommend use the [Universal Enhanced Z-Wave Lock] ([RELEASE] Universal Enhanced Z-Wave Lock Driver for Schlage, Yale, Kwikset, IDLock, Popp, Danalock, August Pro, Keywe, Philia, Samsung) device handler version 3.3.0 or newer for full SmartApp and automatic update notification functionality
##user Unlock/Lock Door Notifications and Actions - Version 03.04.02
- Update due to changes in the ST platform, now you can send SMS notifications to multiple numbers by separating them with a *
##Critical Update for users on version 03.04.01 or 03.04.02
##user Unlock/Lock Door Notifications and Actions - Version 03.04.03
- Fixed a bug which would cause lock/unlock actions to not execute under certain conditions
##user Unlock/Lock Door Notifications and Actions - Version 03.05.00
- Improved speed and resilience to platform issues
- Fixed Auto Unlocking of Schlage deadbolt locks while door is open (some locks would return an busy signal)
- Added support for notifying via text to speech (e.g. Sonos)
- Added support for Bluetooth locks (e.g. Yale)
Recommend use the [Universal Enhanced Z-Wave Lock] ([RELEASE] Universal Enhanced Z-Wave Lock Driver for Schlage, Yale, Kwikset, IDLock, Popp, Danalock, August Pro, Keywe, Philia, Samsung) device handler version 03.03.00 or newer for full SmartApp and automatic update notification functionality
I want to only run a routine when our housekeeper comes. How do I know what slot is her slot?
