[RELEASE] Lock User Unlock/Lock Door Notifications and Actions
You’re website is down. And I just paid you the $35 lifetime subscription too!
Yes we are having an ISP issue. Sorry for the inconvenience. It will be
back up in a few hours.
The website is back up now. Thanks for your patience.
Thanks. The “I just paid you $35!!!” bit was supposed to mostly be a joke. Glad you’re back up.
Feature request.
Is it possible for you to to implement user notification when updated versions is available on your DH´s and SA´s?
Like SMS to me, og Push to me and not the whole family?
###User Unlock/Lock Door Notifications and Actions - Version 03.03.00
  • Added support for reporting unknown users and running actions for master codes/users
  • Added ability to NOT run door lock/unlock action when specified users are present or when in certain modes
  • Reduce notifications verbosity for lock/unlock actions, enable detailed notifications to restore verbosity
Recommend use the [Universal Enhanced Z-Wave Lock] ([RELEASE] Universal Enhanced Z-Wave Lock, Schlage Lock, Yale Lock, Kwikset Lock, IDLock, DanaLock, August Pro and Samsung Lock Device Handler with Alarm Control, Notification, RFID, Door Sensor and advanced features) device handler version 3.2.0 or newer for full SmartApp and automatic update notification functionality
Folks using the ZigBee device handler should update to the latest 1.3a Universal ZigBee device handler. This is to fix an issue with the lock reporting user 255 when using manual or remote locking/unlocking. Thanks for the quick turnaround @jhamstead
##user Unlock/Lock Door Notifications and Actions - Version 03.04.00
  • Added support for selective use notifications only when users are not present
  • Added ability to chime/ring a bell when the door is opened (with option to select modes)
  • Improve quality of notifications and simplified user interface
Recommend use the [Universal Enhanced Z-Wave Lock] ([RELEASE] Universal Enhanced Z-Wave Lock Driver for Schlage, Yale, Kwikset, IDLock, Popp, Danalock, August Pro, Keywe, Philia, Samsung) device handler version 3.2.0 or newer for full SmartApp and automatic update notification functionality
I just purchased and installed 5.04, do I need to reset the lock prior to going to this version or can I just upgrade and re-publish?
If you’ve already got an older version of the SmartApp then just upgrade and republish.
If you’re installing it fresh for the first time, it would be better to clear all the codes from the lock/reset once before starting to use this SmartApp.
##user Unlock/Lock Door Notifications and Actions - Version 03.04.01
  • Added support to report Master Code usage for supporting locks (e.g. Yale, IDLock etc)
Recommend use the [Universal Enhanced Z-Wave Lock] ([RELEASE] Universal Enhanced Z-Wave Lock Driver for Schlage, Yale, Kwikset, IDLock, Popp, Danalock, August Pro, Keywe, Philia, Samsung) device handler version 3.3.0 or newer for full SmartApp and automatic update notification functionality
##user Unlock/Lock Door Notifications and Actions - Version 03.04.02
  • Update due to changes in the ST platform, now you can send SMS notifications to multiple numbers by separating them with a *
##Critical Update for users on version 03.04.01 or 03.04.02
##user Unlock/Lock Door Notifications and Actions - Version 03.04.03
  • Fixed a bug which would cause lock/unlock actions to not execute under certain conditions
##user Unlock/Lock Door Notifications and Actions - Version 03.05.00
  • Improved speed and resilience to platform issues
  • Fixed Auto Unlocking of Schlage deadbolt locks while door is open (some locks would return an busy signal)
  • Added support for notifying via text to speech (e.g. Sonos)
  • Added support for Bluetooth locks (e.g. Yale)
Recommend use the [Universal Enhanced Z-Wave Lock] ([RELEASE] Universal Enhanced Z-Wave Lock Driver for Schlage, Yale, Kwikset, IDLock, Popp, Danalock, August Pro, Keywe, Philia, Samsung) device handler version 03.03.00 or newer for full SmartApp and automatic update notification functionality
I want to only run a routine when our housekeeper comes. How do I know what slot is her slot?
If you install this app from @RBoy it will allow you to define custom actions when specific codes are used, including running a routine. I do this when my housekeeper arrives.
[OBSOLETE] Lock User Management (LUM)
ritchierich, yes, I have it installed and I see how to customize it, but how do I know which user slot belongs to the housekeeper?
If you’re using the app @ritchierich linked then you have to define what the code will use.
If you’re using this app (i.e. no programming only notifications and actions), then you need to find out what slot you’ve programmed into your lock and enter the name against that slot number. If you’ve cleared all codes from your lock and starting from scratch it should start from 1 and work it’s way up.
If you don’t know what slot you’ve programmed in your lock, when you unlock the door using your code, in the device events page on your ST mobile app it will tell you which slot number was used to unlock the door.
Agree with @RBoy, I use the user management app to manage all of my door codes since I have multiple Schlage locks. I have an entry specifically for my housekeeper, kids, parents, etc. The beauty of using this app is if something were to ever change or a code gets compromised, all I have to do is update the app and a minute or so later its changed.
When my housekeeper comes, the house can be seen from the moon because of all the lights she turns on. One day I setup a virtual switch that gets turn on when she enters her code and automated the lights for her. She was startled by it, but now enjoys it because I also turn on all the fans and adjust the thermostat too.
Anyway I can turn the odd refresh sound coming out of my Yale lock? I have the Sensibo DTH running with the app for it and if I change the temperature on my AC, it updates the codes to my lock and I hear a chime. Anytime the DTH for the AC polls, I hear a chime from my lock. Its quite annoying, how can I turn this off? Even turning the sound off on the lock didnt work.
