[RELEASE] Holmes Smart Humidifier With WeMo
I found it on Github - thanks!
Did you get it to work? I added the device handler and smart app though github, and they show up in my ide, but they dont show up on my mobile app
Did you install an instance of the smartapp from the marketplace tab in the mobile app? Check under ā€œmy apps.ā€
Thanks Mark, I found it there. But it won’t find my humidifier. I DL’d the wemo app and connecting it to that to see if that would help but ST still wont find it
So I finally got around to setting up my wemo humidifier now that our radiators have turned on for the season. I’m also unable to add the humidifier from within the smartapp. It works fine with the wemo app. @btk any thoughts? I’m using the ā€œlarge roomā€ humidifier, not sure if that’s the issue. It seems to be pretty much the same thing as the other holmes humidifier w/ wemo, just smaller and with fewer fan settings.
That is the same problem I am having. I was able to get the smartapp on my phone but when i start it and it says it’s looking for the humidifier it never finds it. wemo app finds it just fine. Not sure what im doing wrong.
Same here. Both smartapp and device handler installed, published, but no dice on finding the device. I have the regular wemo humidier, not the large room one.
I looked in the IDE live log when trying to install the smartapp again, and it looks like the app is actually finding the humidifier (the mac address and serial # are correct for the wemo humidifer, I blanked them out below), so I wonder why it’s not visible within the mobile app? @btk if you’re still around can you comment? Thanks.
10:02:49 PM: 	debug    Creating humidifiers
10:02:49 PM: 	debug	FOUND HUMIDIFIER
10:02:49 PM: 	debug	PARSED: [devicetype:04, mac:****,  ip:C0A80069, port:C001, ssdpPath:/setup.xml,  ssdpUSN:uuid:HumidifierB-1_0-****:: urn:Belkin:device:Humidifier:1, ssdpTerm:urn:Belkin:device:Humidifier:1,  hub:00cc9321-44d1-4873-9639-cedd8486d072]
Also, no idea if this is relevant but this error periodically shows up in the live log:
10:10:11 PM: error java.lang.StringIndexOutOfBoundsException: String index out of range: 184 @ line 260
Line 260 in the smartapp code is:
def bodyString = new String(parsedEvent.body.decodeBase64())
Im sure i pasted this wrong but here is the log from mt IDE. It says it found it. I even got the green bar at the top of the app that said it was installed if let it sit there for a minute or two, but when i go to my devices it’s not there.
441a8741-6e87-4c27-aa54-f251792a93fa 9:55:39 PM: debug [name:switch, value:off]
441a8741-6e87-4c27-aa54-f251792a93fa 9:55:39 PM: debug description is on/off: 0
283eab67-8e14-45be-8518-29c333423342 9:55:39 PM: debug [name:switch, value:off]
283eab67-8e14-45be-8518-29c333423342 9:55:39 PM: debug description is on/off: 0
35debb4e-c0f8-4ab2-9529-eda03325559f 9:55:35 PM: debug new port: C001
35debb4e-c0f8-4ab2-9529-eda03325559f 9:55:35 PM: debug old port: C001
35debb4e-c0f8-4ab2-9529-eda03325559f 9:55:35 PM: debug new ip: C0A8010B
35debb4e-c0f8-4ab2-9529-eda03325559f 9:55:35 PM: debug old ip: C0A8010B
35debb4e-c0f8-4ab2-9529-eda03325559f 9:55:35 PM: debug Device was already found in state…
35debb4e-c0f8-4ab2-9529-eda03325559f 9:55:35 PM: debug FOUND HUMIDIFIER
35debb4e-c0f8-4ab2-9529-eda03325559f 9:55:35 PM: debug PARSED: [devicetype:04, mac:94103E591645, ip:C0A8010B, port:C001, ssdpPath:/setup.xml, ssdpUSN:uuid:Humidifier-1_0-221421S0001165::urn:Belkin:device:Humidifier:1, ssdpTerm:urn:Belkin:device:Humidifier:1, hub:5b543508-d65a-44d3-a74b-ef591d888961]
4441ae72-5bb3-44ec-813d-f3f59cfbf330 9:55:35 PM: debug new port: C001
4441ae72-5bb3-44ec-813d-f3f59cfbf330 9:55:35 PM: debug old port: C001
4441ae72-5bb3-44ec-813d-f3f59cfbf330 9:55:35 PM: debug new ip: C0A8010B
4441ae72-5bb3-44ec-813d-f3f59cfbf330 9:55:35 PM: debug old ip: C0A8010B
4441ae72-5bb3-44ec-813d-f3f59cfbf330 9:55:35 PM: debug Device was already found in state…
4441ae72-5bb3-44ec-813d-f3f59cfbf330 9:55:35 PM: debug FOUND HUMIDIFIER
4441ae72-5bb3-44ec-813d-f3f59cfbf330 9:55:35 PM: debug PARSED: [devicetype:04, mac:94103E591645, ip:C0A8010B, port:C001, ssdpPath:/setup.xml, ssdpUSN:uuid:Humidifier-1_0-221421S0001165::urn:Belkin:device:Humidifier:1, ssdpTerm:urn:Belkin:device:Humidifier:1, hub:5b543508-d65a-44d3-a74b-ef591d888961]
35debb4e-c0f8-4ab2-9529-eda03325559f 9:55:35 PM: debug Doing Device Sync!
4441ae72-5bb3-44ec-813d-f3f59cfbf330 9:55:11 PM: debug new port: C001
4441ae72-5bb3-44ec-813d-f3f59cfbf330 9:55:11 PM: debug old port: C001
4441ae72-5bb3-44ec-813d-f3f59cfbf330 9:55:11 PM: debug new ip: C0A8010B
4441ae72-5bb3-44ec-813d-f3f59cfbf330 9:55:11 PM: debug old ip: C0A8010B
4441ae72-5bb3-44ec-813d-f3f59cfbf330 9:55:11 PM: debug Device was already found in state…
4441ae72-5bb3-44ec-813d-f3f59cfbf330 9:55:11 PM: debug FOUND HUMIDIFIER
4441ae72-5bb3-44ec-813d-f3f59cfbf330 9:55:11 PM: debug PARSED: [devicetype:04, mac:94103E591645, ip:C0A8010B, port:C001, ssdpPath:/setup.xml, ssdpUSN:uuid:Humidifier-1_0-221421S0001165::urn:Belkin:device:Humidifier:1, ssdpTerm:urn:Belkin:device:Humidifier:1, hub:5b543508-d65a-44d3-a74b-ef591d888961]
35debb4e-c0f8-4ab2-9529-eda03325559f 9:55:11 PM: debug new port: C001
35debb4e-c0f8-4ab2-9529-eda03325559f 9:55:11 PM: debug old port: C001
35debb4e-c0f8-4ab2-9529-eda03325559f 9:55:11 PM: debug new ip: C0A8010B
35debb4e-c0f8-4ab2-9529-eda03325559f 9:55:11 PM: debug old ip: C0A8010B
35debb4e-c0f8-4ab2-9529-eda03325559f 9:55:11 PM: debug Device was already found in state…
35debb4e-c0f8-4ab2-9529-eda03325559f 9:55:11 PM: debug FOUND HUMIDIFIER
35debb4e-c0f8-4ab2-9529-eda03325559f 9:55:11 PM: debug PARSED: [devicetype:04, mac:94103E591645, ip:C0A8010B, port:C001, ssdpPath:/setup.xml, ssdpUSN:uuid:Humidifier-1_0-221421S0001165::urn:Belkin:device:Humidifier:1, ssdpTerm:urn:Belkin:device:Humidifier:1, hub:5b543508-d65a-44d3-a74b-ef591d888961]
4441ae72-5bb3-44ec-813d-f3f59cfbf330 9:55:09 PM: debug PARSED: [mac:94103E591645, headers:SFRUUC8xLjEgNDAwIEJhZCBSZXF1ZXN0DQpTRVJWRVI6IFVuc3BlY2lmaWVkLCBVUG5QLzEuMCwgVW5zcGVjaWZpZWQNCkNPTk5FQ1RJT046IGNsb3NlDQpDT05URU5ULUxFTkdUSDogNTANCkNPTlRFTlQtVFlQRTogdGV4dC9odG1s, body:PGh0bWw+PGJvZHk+PGgxPjQwMCBCYWQgUmVxdWVzdDwvaDE+PC9ib2R5PjwvaHRtbD4=, hub:5b543508-d65a-44d3-a74b-ef591d888961]
35debb4e-c0f8-4ab2-9529-eda03325559f 9:55:09 PM: debug PARSED: [mac:94103E591645, headers:SFRUUC8xLjEgNDAwIEJhZCBSZXF1ZXN0DQpTRVJWRVI6IFVuc3BlY2lmaWVkLCBVUG5QLzEuMCwgVW5zcGVjaWZpZWQNCkNPTk5FQ1RJT046IGNsb3NlDQpDT05URU5ULUxFTkdUSDogNTANCkNPTlRFTlQtVFlQRTogdGV4dC9odG1s, body:PGh0bWw+PGJvZHk+PGgxPjQwMCBCYWQgUmVxdWVzdDwvaDE+PC9ib2R5PjwvaHRtbD4=, hub:5b543508-d65a-44d3-a74b-ef591d888961]
35debb4e-c0f8-4ab2-9529-eda03325559f 9:55:02 PM: debug PARSED: [mac:94103E591645, headers:SFRUUC8xLjEgNDAwIEJhZCBSZXF1ZXN0DQpTRVJWRVI6IFVuc3BlY2lmaWVkLCBVUG5QLzEuMCwgVW5zcGVjaWZpZWQNCkNPTk5FQ1RJT046IGNsb3NlDQpDT05URU5ULUxFTkdUSDogNTANCkNPTlRFTlQtVFlQRTogdGV4dC9odG1s, body:PGh0bWw+PGJvZHk+PGgxPjQwMCBCYWQgUmVxdWVzdDwvaDE+PC9ib2R5PjwvaHRtbD4=, hub:5b543508-d65a-44d3-a74b-ef591d888961]
4441ae72-5bb3-44ec-813d-f3f59cfbf330 9:54:56 PM: debug PARSED: [mac:94103E591645, headers:SFRUUC8xLjEgNDAwIEJhZCBSZXF1ZXN0DQpTRVJWRVI6IFVuc3BlY2lmaWVkLCBVUG5QLzEuMCwgVW5zcGVjaWZpZWQNCkNPTk5FQ1RJT046IGNsb3NlDQpDT05URU5ULUxFTkdUSDogNTANCkNPTlRFTlQtVFlQRTogdGV4dC9odG1s, body:PGh0bWw+PGJvZHk+PGgxPjQwMCBCYWQgUmVxdWVzdDwvaDE+PC9ib2R5PjwvaHRtbD4=, hub:5b543508-d65a-44d3-a74b-ef591d888961]
35debb4e-c0f8-4ab2-9529-eda03325559f 9:54:56 PM: debug PARSED: [mac:94103E591645, headers:SFRUUC8xLjEgNDAwIEJhZCBSZXF1ZXN0DQpTRVJWRVI6IFVuc3BlY2lmaWVkLCBVUG5QLzEuMCwgVW5zcGVjaWZpZWQNCkNPTk5FQ1RJT046IGNsb3NlDQpDT05URU5ULUxFTkdUSDogNTANCkNPTlRFTlQtVFlQRTogdGV4dC9odG1s, body:PGh0bWw+PGJvZHk+PGgxPjQwMCBCYWQgUmVxdWVzdDwvaDE+PC9ib2R5PjwvaHRtbD4=, hub:5b543508-d65a-44d3-a74b-ef591d888961]
4441ae72-5bb3-44ec-813d-f3f59cfbf330 9:55:02 PM: debug PARSED: [mac:94103E591645, headers:SFRUUC8xLjEgNDAwIEJhZCBSZXF1ZXN0DQpTRVJWRVI6IFVuc3BlY2lmaWVkLCBVUG5QLzEuMCwgVW5zcGVjaWZpZWQNCkNPTk5FQ1RJT046IGNsb3NlDQpDT05URU5ULUxFTkdUSDogNTANCkNPTlRFTlQtVFlQRTogdGV4dC9odG1s, body:PGh0bWw+PGJvZHk+PGgxPjQwMCBCYWQgUmVxdWVzdDwvaDE+PC9ib2R5PjwvaHRtbD4=, hub:5b543508-d65a-44d3-a74b-ef591d888961]
35debb4e-c0f8-4ab2-9529-eda03325559f 9:54:51 PM: debug PARSED: [mac:94103E591645, headers:SFRUUC8xLjEgNDAwIEJhZCBSZXF1ZXN0DQpTRVJWRVI6IFVuc3BlY2lmaWVkLCBVUG5QLzEuMCwgVW5zcGVjaWZpZWQNCkNPTk5FQ1RJT046IGNsb3NlDQpDT05URU5ULUxFTkdUSDogNTANCkNPTlRFTlQtVFlQRTogdGV4dC9odG1s, body:PGh0bWw+PGJvZHk+PGgxPjQwMCBCYWQgUmVxdWVzdDwvaDE+PC9ib2R5PjwvaHRtbD4=, hub:5b543508-d65a-44d3-a74b-ef591d888961]
4441ae72-5bb3-44ec-813d-f3f59cfbf330 9:54:50 PM: debug PARSED: [mac:94103E591645, headers:SFRUUC8xLjEgNDAwIEJhZCBSZXF1ZXN0DQpTRVJWRVI6IFVuc3BlY2lmaWVkLCBVUG5QLzEuMCwgVW5zcGVjaWZpZWQNCkNPTk5FQ1RJT046IGNsb3NlDQpDT05URU5ULUxFTkdUSDogNTANCkNPTlRFTlQtVFlQRTogdGV4dC9odG1s, body:PGh0bWw+PGJvZHk+PGgxPjQwMCBCYWQgUmVxdWVzdDwvaDE+PC9ib2R5PjwvaHRtbD4=, hub:5b543508-d65a-44d3-a74b-ef591d888961]
We seem to be SOL as far as a response from the app developer goes. Maybe @kevintierney can help? He got a shoutout in the first post from @btk for writing another Holmes Wemo integration app that this one’s based on.
I think your right. Ill keep working on it and let you know if i figure it out.
Ok I give where is the Code??? Been looking around through this thread, community, and github…is this still a good app?
Where did you find it …
The developer didn’t link directly to his github repository in the original post but he did provide the info needed if you know how to use the ST GitHub integration.
http://docs.smartthings.com/en/latest/tools-and-ide/github-integration.html
Let us know if it works for you, several of us seem to be having issues getting the app to find our humidifier.
I the link must be outdated because I do not have an option in my IDE under My Apps and or My Handlers per the instructions to add github.
I figured it out…
any luck getting it to work
Yep so far everything is up and working.,
Do you mind giving me a recap of what you did. I still can’t get mine to work
