Still experimenting with PlugPlayer.
I can run one instance of PlugPlayer as DLNA Controller to control music from my Synology NAS (defined as the DLNA Server) and have it played on another instance of PlugPlayer running on a different device and specified as the DLNA Renderer. When I try to send sounds using your App I have the following problems:
1,After the sound (barking dogs) plays on the renderer it does not go back under the control of the DLNA controller instance of Plugplayer on the other device. Effectively it gets stuck with the barking dog sound as the only thing in its playlist.
2. The DLNA renderer does not persist as a thing in SmartThings. After use the Thing goes to ānot presentā and when it is run again it does not become present again. I have to delete it as a thing, delete the MediaRenderer (Connect), recreate the MediaRenderer (Connect), and then rerun it to recreate a new PlugPlayer DLNA renderer thing before I can go again.
Hi , please read about control point in first post, not all control points works to resume, its about how control point its made, most of the Media Renderers do not accept containers, then must to use a in line control point, most of Mediarenderers do not accept pasue , and most of the mediarenderer do not accept suspend , then the music must to stop, play a message and start the song again.
Can anyone help with this error below? Not sure if itās normal. Noticed while looking for something else. I updated to the latest version. It can find my Kodis and control them so I think the app is working. I havenāt tried sending audio message yet.
java.lang.StringIndexOutOfBoundsException: String index out of range: 184 @ line 273
Hi @Paul_Preston, The section is to identify the headers when try to refresh the ip if it has changed, its no necessary but seems the response from your mediarenderer do not have headers. I have update to avoid a error when the header is empty, try it , sorry I have not much time to test it.
Hi Spinny, I have tested the plugPlayer app for ios, the PP is a virtual MediaRenderer and works , but its very inconsistent, just freeze every time out , and need to be launched again to get a different port, MediaRenderer connect find the new port every 3 minutes but its necessary to relaunch PP every time its frizzed, sorry but PP does not work fine with ST, Its necesary to find other app who converts the ios in a media renderer
mdawson
(Different Computers. So happy with Indigo.)
423
Looks like either Iām reading it wrong, or the code version (the one IN the code itself) isnāt updated. It matched what I had installed, but when I āupdatedā with the code on GitHub, things started allowing me to save them.
Iām not at home so I canāt actually test function, but the SmartApp allowed me to fully configure it.
mdawson
424
OK so Iāve tried TTS a couple ways and nothing happens.
Maybe itās a problem with my unconfirmed speaker. no idea if itās actually compatible, though specs suggest it is. Any ideas on how I could go about figuring out if Iāve got a functioning system with unsupported hardware vs. supported hardware and something wrong in my ST setup?
