Hi Everyone!
It’s my first SmartThings project. But based on some examples out there I came up with a Java/SpringBoot backend based monitor device handler.
Hi Everyone!
This looks interesting. Other than the screenshot you showed, does it display any other stats? I assume this is a one-way communication to ST, but not back to the Raspberry Pi?
Yes so far. The plan is to make my daughter’s LED Firefly string driven by a pi nano. So the next one would be to turn the LED on and off.
Nice implementation.
I made 2 projects using the pi as a gateway to drive BTLE devices here and here and something I’d like to implement is a self discovery of the pi rather than emtering the IP and port.
I saw a ssdp development from a member that I planned report but got lazy…
Maybe you can add that too and make your dth plug and play for a ST style user experience.
Thanks for this project, I’ve been looking for something like this. I’ve set everything up, however I’m running into a problem on the RPi when I start the jar, in short port 8080 is already in use, how do you change the port your project uses?
That’s a cool idea. I google really quickly and there’re implementations out there to implement UPnP with SpringBoot. I’ll try to add this feature!
I created an issue on GitHub for this.
Hi,
Thanks for checking this out! The monitor running on the Pi is a standard SpringBoot application. If you want to modify the embedded Tomcat server’s HTTP port from the default 8080 to let’s say 8081 start up the application with this command:
java -jar -Dserver.port=8081 raspberrypi.monitor.jar
Thanks for coming back to me, that sorted the port issue and the RPi server is up & running and all is working.
Excellent.
My personal difficulty was to define the right type of UUID. Most of the examples I saw were audio streaming cases to the developer was using a standard audio type of descriptor. Appreciate your solution and findings.
I’ll try to find again the ST member one as it was for wired alarm object and he defined many types of devices. Will check again later today if time.
Cool, happy to hear that!
Let me know if you find out something!
Here you go.
Thank you!
I’ve added UPnP support!
Very good! I am checking that. Lazy me…
Okay hoping to get a little help here I’m having a total brain fart. I have everything setup on the Pi but need the path to the jar file I have to run and for the life of me can’t figure that out. Anyone provide any insight?
If you check out the github repo and have maven and jdk8 installed, just run mvn clean install. The jar file is going to be created under the target folder. This folder is cleaned every time you build the project, so I suggest to move the jar file out from that location to somewhere else. Let me know if that helped!
Thanks I got it after some sleep and a cup of coffee I was able to think straight.
Next question…I have everything setup and can access the API via the web but Discovery is not finding anything in the SmartApp any thoughts?
There’re a couple of things I could think of
java -Dlogging.level.com.cl0udninja.raspberrypi.monitor=DEBUG -jar monitor.jar to see more logging and figure out what could be wrong.If it still doesn’t work, you can add the device manually on the ST IDE, just go to Devices/New Device for type use the Raspberry Pi Monitor and for device id you need the IP address and the port (default is 8080) in this format ip:port. You need to convert both values to Hex.
You can use this online tool for the IP: https://ncalculators.com/digital-computation/ip-address-hex-decimal-binary.htm
And this for the port: https://ncalculators.com/digital-computation/ip-address-hex-decimal-binary.htm
So if your Pi’s IP is 192.168.1.100 and the monitor runs on port 8080 the value you need to provide for Device Network Id is: C0A80164:1F90
I hope this works. If you send me the logs I could probably pinpoint what the problem is with UPnP
