Does anyone know how to pair my switches Ge with my smartthings hub? Ptapt-whca
I have tried to add device and then put in pairing mode by pushing on the 2 buttons with no success. The app searches for devices but cannot find either switch. Is there another way to pair. Manually?
If you want to add the Tapt switches, you need to use a custom device handler, instructions posted in the following thread:
At some point, the Tapt switches could be recognized by ST as a Zigbee switch, but after an update from Wink this could no longer be used to pair them. Keep in mind that the device type required will not update the status of the switch in the app if you press the switch buttons.
As my two cents, if you are to use the ST hub, get rid of these switches. They are quirky (pun intended) and will go offline randomly. I am down to the last one of these and will be replacing it shortly. Just my two cents.
That one says the custum device type is no longer needed. I have added the device type in ide anyway but where should it show up in smartthings app? The problem is that when i search for the device, the st hub cannot locate it.
Update [12/14/2015]
This custom device type is no longer needed. Your best method is to remove the device from ST, remove the published Device Type and add to ST. It will add as a ZigBee Switch which does on/off and instant reporting.
That was back when ST and the Tapt did play nice together. For some reason after a Wink update it stopped working like that.
After you add the device in the IDE, you need to go to the “Add a thing” button in the ST app and follow the instructions to add the switch by using both the top and bottom button.
Did you power reset the switch? Tapts are known for getting stuck into an unprairable state until you flip the breaker for the circuit.
Do you have a Wink hub you can try if it is working? Maybe it is a bad switch?
Yes I did power reset the switches. I have 2 and they are both doing the same thing.
I dont think they are going into pairing mode or factory reset. If you hold the 2 buttons both lights blink rapidly then stay lit for 1 second and turn off.
Hub and router are 8 feet away. Clear line of sight. No other zig bee devices. I may have had a wall plug before but I don’t believe it’s plugged in still.
How far away are the switches from the hub? Might want to try and get them closer.
Also, if you have a long ethernet cable, just to try, get the hub farther away from the router. WiFi might interfere with Zigbee.
Is the device controller still required. I had it working for the longest time but it stopped recently. I removed and did a hard reset and was able to add it back. It worked for a single time then nothing. The app shows the toggle on and off. Even when asking Alexa to turn or off the light but the light does not turn on or off unless I press the physical button.
It worked for me too and I was able to switch over to the custom handler. My point was even when asking Alexa to turn on, i can see in the app the toggle turned on. However the lights did not.
I know this is a late question, but I’m just migrating from Wink, and still have a couple of these Tapt switches. I published the device handler to the IDE, but when I search for the switch, it just shows up as “Thing” and does not function.
