Question about connecting 12 volt LED lights
If you want them as 3 completely separate items in ST then the easiest way will be to have 3 devices. Either 3 sockets (with two additional power supplies) or 3 Fibaro relays connected in parallel to a single power supply.
The Orvibo relay will also work (I have one controlling my garage door). ST detects it and you can use the default Zigbee relay device type handler (DTH). At some point I hope to get the Orvibo working so that I can control 3 items (not just one).
Not sure how familiar you are with the IDE and custom DTH, have a read of @JDRoberts guide if needed here:
Hope that helps.
