Hi all,
I have been using the Fibaro shutter 3 and device handler (https://github.com/philh30/smartthings/tree/master/fibaro-fgr-223.src) with no issue, works great.
With that I was able to open the shutter as a blind in Google Assistant with the smartthings -> google assistant driver with “turn on name shutter” or turn off…
With the upgrade in december I am now getting that the device is not setup as a response instead of actioning the command as expected.
I was hopeful that the integration was upgraded to allow for open or close instead of turn on or turn off commands. Both do not work.
I can check with google is the shutter open or closed and it works (fairly useless) but can’t instruct it to open close.
I am interested if this has happened to anyone else or if there is a fix.
Matt
