I have been having trouble with a presence sensor reliably working, often it shows as away when it is in fact present. I have read that presence sensor can be tricky if the devise is on the edge of the zigbee mesh. Is it correct that a ST plug/outlet can expand the mesh? If so, where can I buy one? Amazon don’t stock them! Thanks
There were lots of problems with them not being safe… I think they have been withdrawn from sale until they can be fixed.
I don’t use any to switch anything… just use them as expensive repeaters.
I wouldn’t waste your time and money on an ST Outlet (UK version), I’ve found they blatantly refuse to repeat zigbee signals from battery powered devices, what you need is an Xbee, which is what it’s actually designed for, routing Zigbee packets, there are a few very helpful threads on here that will explain everything about them.
