This device handler will allow you to treat each clamp as a separate device. I think it is in beta right now but looks like they got it working properly. It has amps I believe.
This DTH is designed to work with 3, 2 and 1 clamp configurations but was only tested on 3 clamp configuration so any input is welcome.
This is a composite device. That means it will install a virtual device for every clamp (except for 1 clamp configuration) and a main device displaying information for the whole HEM. It requires “Aeotec HEM Gen5 Child Device” to work correctly so install both parts of the DTH before switching to it.
This DTH provides the following functionality:
Power Monitoring
Energy Monitoring
Voltage Monitoring
Current Monitoring
Configuration for following parameters:
Power and Energy detection mode
Reporting Threshold
HEM threshold
Clamp 1 threshold
Clamp 2 threshold
Clamp 3 threshold
HEM percentage
Clamp 1 percentage
Clamp 2 percentage
Clamp 3 percentage
CRC-16…
