Sorry, @csstup I don’t like logs with the developer format, one goes crazy moving the side scroll bar to see the full messages and you don’t know where you’re going.
Do not send me in DM, these things may interest more users, that is my opinion
If you want to hide the log you can use the Hidden format and they are hidden until someone clicks on it to see it. As this
Logs, click to see
2022-11-30T17:48:06.347349698+00:00 DEBUG Z-Wave Sensor and Child Thermostat Mc Fibaro Open/Closed Sensor device thread event handled
2022-11-30T17:48:11.286092699+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Z-Wave command(5a06a0f1) transmit status: TRANSMIT_COMPLETE_NO_ACK
2022-11-30T17:48:16.576068408+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Z-Wave command(3d711379) transmit status: TRANSMIT_COMPLETE_NO_ACK
2022-11-30T17:48:21.576057908+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Z-Wave command(ad08ec0c) transmit status: TRANSMIT_COMPLETE_NO_ACK
2022-11-30T17:48:26.546063409+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Z-Wave command(c580f89b) transmit status: TRANSMIT_COMPLETE_NO_ACK
2022-11-30T17:48:31.646061618+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Z-Wave command(0939fd0a) transmit status: TRANSMIT_COMPLETE_NO_ACK
2022-11-30T17:48:33.612161076+00:00 DEBUG RDG - Zigbee Temp driver device thread event handled
2022-11-30T17:48:36.676045410+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Z-Wave command(6089d74d) transmit status: TRANSMIT_COMPLETE_NO_ACK
2022-11-30T17:48:41.676047786+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Z-Wave command(8ecbb844) transmit status: TRANSMIT_COMPLETE_NO_ACK
2022-11-30T17:48:46.736100661+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Z-Wave command(af1e4d96) transmit status: TRANSMIT_COMPLETE_NO_ACK
2022-11-30T17:48:51.806119912+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Z-Wave command(e2a35935) transmit status: TRANSMIT_COMPLETE_NO_ACK
2022-11-30T17:48:56.876078329+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Z-Wave command(e6515ce6) transmit status: TRANSMIT_COMPLETE_NO_ACK
The hidden format doesn’t help me: my voice reader will still read each line.
Just take anything that’s detailed to a different thread. This thread should be limited to about two posts per device: one with the request, and one with a developer response with a link to another thread, where you can discuss it further.
I’m sure that’s an interesting conversation, but it’s off-topic for this thread. Please start a new thread under meta if you want to discuss formatting options and preferences.
I just came home to find my christmas and walkway lights that are controlled via an Aeotec Smart Strip are no longer working with the erocm123 DTH. Any chance someone is working on an Edge driver?
There’s also a better Ecobee handler from SANdood that would be great to see brought over as well.
I have 2 request one is a minoston 4 button mini mote that shows up as an aeotec wallmote under a default device handler Raw Description zw:Ss2a type:1800 mfr:0312 prod:0924 model:D001 ver:1.00 zwv:7.13 lib:03 cc:5E,55,9F,6C sec:86,85,8E,59,72,5A,73,80,5B,87,70,84,7A
Second is keen smart vents that should work on the smartthings edge drive by samsung but for what ever reason will not add (I tried 4 different ones multiple times) raw discription:
01 0104 0003 00 0D 0000 0001 0003 0004 0005 0006 0008 0020 0402 0403 0B05 FC01 FC02 01 0019
I removed the Bosch handler from ide and removed the device. Enrolled the edge driver. Scanned nearby but nothing returned. Removed batteries and then put them in. Smartthings just added it back without processing add device. However, it’s used the old driver not the edge one. I removed it again and tried to add it back, However, I am stuck to add it back to smartthings.
hopefully you didn’t remove in the order you stated above. remove the device first then remove the custom device handler in IDE. if you tried the other way, it should have indicated it can’t remove the device handler while in use by the device.
@Mariano_Colmenarejo , I run smartthings edge:drivers:logcat for Zigbee Motion Sensor Mc then scan nearby, but nothing is printed. weird. Do I miss anything?
