Post Requests for Zwave Edge Drivers Here (community-created)
perfect! Thanks @Mariano_Colmenarejo!
Im after an edge driver for a z-wave electric meter
Can anybody help on this one.
Home Energy Meter (2nd Edition) Model: DSB28-ZWEU (868.42MHz) Input: 230VAC, 50Hz, 10mA Aeon Labs
Hi,
I am currently migrating my Fibaro Walli Outlets FGWOF-011 from Hubitat to Smartthings. The device is recognized as a metering switch and the primary functions all work great, being switch, power meter and energy consumption. Unfortunately I am unable to set any of the advanced parameters of the Fibaro device. The available parameters are documented here: Walli Outlet - E/F | FIBARO Manuals I am actually only interested in changing parameter 11, as by default the LED ring is very bright and lights up the bedroom at night. Would it be possible to have a custom driver with this capability? Thank you in advance for having a look.
Hi @RobinScavok
I had forgotten that I was going to try to make a driver to configure the parameters of zwave devices. :man_facepalming:
Let’s see if tomorrow I get on today I have other things to do
UPDATE:
Driver published
Has anyone created an Edge driver for the Monoprice HKZW-DWS01 Door/Window Sensor?
Raw Description zw:S type:0701 mfr:0208 prod:0201 model:0008 ver:1.05 zwv:4.34 lib:03 cc:5E,86,72,71,59,85,80,84,73,70,7A,5A
I know this has been requested before but just wondering if any one would consider converting the Fully Kiosk Browser DTH in the linked post to Edge (if it’s even possible)?
I use an older Monoprice Z-wave contact sensor (#10795) tied in to my smoke detectors via a relay (via external contacts). I’d like this sensor to be reflected in Smartthings as a smoke detector.
I also use the same sensor as a water sensor to identify leaks. I’d like this sensor to be reflected in Smartthings as a leak detector.
Are either of these configured as of yet?
Thanks!
@damohabir
Just requested the same. Have you come up with anything yet? Thanks.
I know it’s a long way around the barn, exactly what you don’t want for emergency alerts, but @taustin does have a virtual smoke alarm and a virtual water sensor which can both be actuated (turned on or off) from a regular routine.
So you could have a regular routine where the trigger was your contact sensor and the action was “turning on“ the virtual device which serves as the alert trigger in smartthings home monitor or another automation.
The good news is all of this does run locally, unlike the old groovy custom versions.
So I don’t know if it’s of any interest or not, but it might be a workaround for the time being. :thinking:
(The topic title is a clickable link)
@damohabir
an edge driver for tuya local would be nice
The problem is that Tuya uses a lot of proprietary code, and they use different proprietary clusters for different models. So it all comes back to the model number. There are several edge drivers already for different tuya models. Which devices specifically were you looking for?
And have you tried checking the quick browse lists in the community-created wiki? That’s where you can find the existing edge Drivers for Tuya devices.
https://thingsthataresmart.wiki/index.php?title=How_to_Quick_Browse_the_Community-Created_SmartApps_Forum_Section#Quick_Browse_Links_for_Edge_Drivers
How about a Edge Driver for Ring Contact and Motion Sensors.
Hi @Mariano_Colmenarejo
Thank you very much for de device config driver. It works perfectly! Now I can finish my migration to Smartthings. Hero!
@Helder_Rodrigues if you use the search function in the forum and search “edge Z-Wave”, you’ll see a list of all the edge drivers for Z-Wave that have been done, this is the easiest and quickest way.
Looking for edge drivers for:
BeSense Open/Closed Sensor
  • IM20 Z-Wave
  • zw:Ss2 type:0701 mfr:027A prod:0301 model:0012 ver:1.03 zwv:4.61 lib:03 cc:5E,55,98,9F sec:86,85,59,72,5A,73,80,71,30,84,70,6C,7A
  • MSR: 0214-0002-0001
  • networkSecurityLevel: ZWAVE_LEGACY_NON_SECURE
Homeseer leak sensor
LS100+ Water Sensor
  • zw:S type:2001 mfr:000C prod:0201 model:000A ver:1.04 zwv:4.61 lib:03 cc:5E,85,59,55,86,72,5A,73,80,71,84,70,6C,31,30,7A
I have this one on my list to do if no one else already has. I have a working DTH I built for the LS100+ as it has some oddities and errors in the manual vs how the device actually responds/performs. I have a bunch of these sensors in production now.
Thank you. Keep us posted.
Also need Edge driver for:
Zooz Motion Sensor ZSE18
  • networkSecurityLevel: ZWAVE_S2_UNAUTHENTICATED
Zooz ZEN74 700 Toggle Dimmer
  • zw:Ls2a type:1100 mfr:027A prod:7000 model:A004 ver:1.02 zwv:7.13 lib:03 cc:5E,55,9F,6C sec:86,26,70,5B,85,8E,59,72,5A,87,73,7A
  • networkSecurityLevel: ZWAVE_S2_AUTHENTICATED
Zooz is working on official drivers for all their devices. They haven’t released them yet because they’ve been waiting for Edge itself to stabilize. So I’d expect these to be covered by the time the cutoff actually gets here.
Hello I’m looking for a driver for a Zwave dual switch and for Philio pan08 shutter controller
Dual Switch
Metrics * Received Messages From Device: 1798
  • Received Messages From Device (Duplicates): 51
  • Messages Transmitted to Device: 1784
  • Messages Transmitted to Device (Failures): 0
  • Updated Time: 2022-08-18 4:22 PM WEST
    Data * networkSecurityLevel: ZWAVE_LEGACY_NON_SECURE
    Raw Description zw:L type:1001 mfr:0118 prod:0311 model:0304 ver:2.05 zwv:4.05 lib:03 cc:5E,86,72,5A,73,85,59,25,20,27,70,2B,2C,60,7A epc:2
    Current States * switch: off
  • checkInterval: 1920 s
Philio pan08
Metrics * Received Messages From Device: 3552
  • Received Messages From Device (Duplicates): 112
  • Messages Transmitted to Device: 1974
    Raw Description zw:L type:1107 mfr:013C prod:0001 model:0015 ver:1.05 zwv:4.38 lib:03 cc:5E,86,72,5A,85,59,73,25,26,70,71,32,7A,2B,2C
    Current States * shadeLevel: 100 %
  • level: 100 %
  • checkInterval: 14400 s
  • windowShade: open
  • supportedWindowShadeCommands:
[ “open”, “close”, “pause” ]
Preferences (edit) Name Type Value
preset number
Execution Location Cloud
This one is in the stock zwave-sensor driver:
