Post Requests for Zigbee Edge Drivers Here (community-created)
Hi, could you please add this fingerprint to the Zigbee Button Mc driver? It’s a Tuya Smart Knob (Moes).
  • Manufacturer: _TZ3000_1fqpj6qz
  • Model: TS004F
Thank you in advance!
You can try ask @zambobmaz to add to his driver. open an issue in his Github:
https://github.com/obmaz/smartthings_edge_driver
Una pena que no esté más por aquí, pero muchísimas gracias por toda la ayuda que nos brindó a todos nosotros durante estos años. ¡La mejor de las suertes en lo que sea que usted haga!
PD: Los drivers que usted generosamente nos brindó ¿van a seguir funcionando sin usted?
@Mariano_Colmenarejo is still around and his drivers work well!
Hi @Mariano_Colmenarejo,
​I would like to request a new fingerprint for your “Zigbee Smoke Detector Mc” driver. It is a Tuya Smoke and CO Combination Detector.
​I have already enrolled in your channel and installed the correct driver on my Hub. However, when I try to “Select another driver”, I only see “Zigbee Device Config Mc” and “Zigbee Thing Mc”. Your “Zigbee Smoke Detector Mc” is NOT appearing in the list of available drivers for this device.
​It seems the fingerprint is missing from the driver’s library. Here are the details:
​Manufacturer: _TZE284_6ycgarab
​Model: TS0601
​I am attaching the screenshots showing the manufacturer ID and the driver list. Could you please add this fingerprint to your driver?
​Thank you very much for your help and for your great work!
Since this device uses EF00 cluster , @Mariano_Colmenarejo won’t support it. You can Try @w35l3y EF00 specific driver and select Smoke Sensor profile
https://api.smartthings.com/invite/6Vjd4YPVJwjN
Thank you @dotan_shai for the clarification.
​I have already installed @w35l3y’s Personal Tuya Devices driver, but the device is still recognized only as a ‘Zigbee Thing’. I’ve already contacted the developer to request the addition of this specific fingerprint (_TZE284_6ycgarab).
​I’m now waiting for the update to be released so I can finally pair it correctly. Thanks again for the support!
My understanding of that generic EF00 driver is that you change the driver and configure it according to the instructions to fit your device without needing device specific fingerprints.
Hi @motocicletta, thanks for the suggestion.
​I am aware that the EF00 driver allows manual configuration, but since this is a Smoke and CO detector, I want to be 100% sure the mapping is correct for safety reasons.
​If anyone knows the specific DP IDs for this model (_TZE284_6ycgarab), I’d be happy to try manual configuration. Otherwise, I think waiting for @w35l3y to officially add it is the safest bet. What do you think?
Well, i think this train already leaved the station :sweat_smile:
3rd party developed drivers are “unsupoorted” by smartthings platform, so isnt assured to work 100%.
if you you want to be 100% sure the device will function correctly, your best bet is to buy a officially suported device.
Hi @Mariano Colmenareio,
Could you please add the new Sonoff
ZBMINIR2 (with Neutral) to your Zigbee
Switch Mc driver?
Model: ZBMINIR2
Manufacturer: SONOFF
Endpoint: Ox01
I’m looking forward to using the “Power On
State” feature with your driver.
Thank you very much!
I am new to using edge drivers and am looking for one to support this device:
Model: TS0043
Manufacture: _TZ3000_1kmurvlx
This device is a Moes Zigbee Switch - 3 gang 9 scenarios. Is there one available?
Thank you very much!!!
@zambobmaz already have a driver for this device. His Channel is here:
https://api.smartthings.com/invitation-web/accept?id=2d6da83b-ae22-4fda-8af5-bbb8890872d4
Not sure if this will work !!!
I copied all zigbee-switch-v6.5 from @Mariano_Colmenarejo Github . Also adde ZBMINIR2 fingerprint. All was done by AI (Co-Pilot). My channel is here.
https://bestow-regional.api.smartthings.com/invite/Q1jP7By0KVlL
Let me know if I succeed :grinning_face:
Driver Id 8ec67fcf-49d4-4b87-bfbd-e51c4f903a75
Name Zigbee Switch SD
Package Key Zigbee_Switch
Version 2026-05-08T11:19:47.332378062
Please note the new features of:
Cluster 0xFC11 Custom Attributes
Attribute ID Type Meaning
external_trigger_mode 0x0016 uint8 Edge/Pulse/Follow modes
detach_relay 0x0017 bool Relay follows external switch or not
turbo_mode 0x0012 int16 Boost mode (9=off, 20=on)
Are not supported !! Only simple single switch
It worked perfectly!
Thank you so much for adapting this driver, it will be a lifesaver! :raising_hands:
@Mauro_Ferreira Maybe these can be set with this driver
