Post Requests for Zigbee Edge Drivers Here (community-created)
Info:
Hi @Mariano_Colmenarejo, thanks for the amazing work you’ve done here!
Could this be added? Found this Model before, but with different Manufacturer
Hi @Banzo182
Added to this driver version
 Name         Zigbee Motion Sensor Mc
 Version      2023-08-03T21:07:27.598628001
- id: "TUYATEC-zw6hxafz/RH3040"
    deviceLabel: RH3040 Motion Sensor
    manufacturer: TUYATEC-zw6hxafz
    model: RH3040
    deviceProfileName: motion-battery
I’m looking at buying the above device, but noticed in the SmartThings app there doesn’t seem to be native support for it. There’s support for the Aqara Roller Shade Controller (model number: ZNGZDJ11LM), but not the E1. Unfortunately we can’t buy the former here in the UK, and there’s no other roller shade driver made by any manufacturer other than the Aquara.
Does anyone have an Edge or Custom driver for the E1? Or perhaps the native driver for the ZNGZDJ11LM will have sufficient compatibility to work with the E1?
Looking for a driver for IKEA Rodret Dimmer
Device specification:
Update: I have exchanged this device for another button instead. Leaving this for anyone else who might need a driver for this.
A post was merged into an existing topic: Post Requests for LAN/WIFI Edge Drivers Here (community-created)
Still looking for edge driver for Xfinity XHK1-UE Keypad. Anyone have any luck with this?
Mine is still showing as β€œZigbee thing”
Not sure is this helps… @Mariano_Colmenarejo ?
Hi, I’m looking for zigbee edge driver for Namron 2-channel button:
Hi @Mariano_Colmenarejo, can you add the fingerprint at β€œzigbee light multifunction MC” driver?
@frmi Did you find any working driver for the Rodret, please?
No. I returned it and bought a Shortcut button instead. That works after a bit of pairing/re-pairing.
Ah, shame. I bought the Rodret mostly for AAA battery but the device has caused more trouble than joy.
Hi @Saulo_Vianna
 Name         Zigbee Light Multifunction Mc
 Version      2023-08-08T14:44:06.420410081
- id: "GLEDOPTO/GL-G-007Z"
    deviceLabel: GLEDOPTO GL-G-007Z
    manufacturer: GLEDOPTO
    model: GL-G-007Z
    deviceProfileName: rgbw-level-colortemp-2700-6500
Hey
anyone got this to work with edge?
maybe someone who can throw the fingerprint into a similar driver
works fine with zigbee switch, but only relay 1.
maybe it will work with your Zigbee Multi Switch and Child Mc?
Hi @Charles_Booth
Sorry, I don’t have any drivers for multiple zigbee buttons and I’m not good at handling these devices
Well… It was worth a try. You seem to be the go-to here. Thank you for the prompt response!
Posted this in the zwave thread at first by accident woops.
Request Sage Single Gang zigbee battery Light Switch 206611 By Hughes Echostar
Back when the old ide was a thing i used to be able to set this to zigbee button and it would work. I believe all that has to be done to get this to work is to change the fingerprint but im not sure where to start with the smartthings cli. Any help appreciated thanks.
Anyone updated this one (GE Smart switch 45853):
Hi @Christian_Graversen
Install zigbee thing Mc and perform a driver change to see complete device data
