Dear @Mariano_Colmenarejo, I have switches from Lumi Vietnam, they are 1,2,3,4 gangs switches. Pls help me add them to your multi switches driver, I have problem with them when I can not control them invidually.
Hereafter are the info I got from IDE and Api browser.
Lumi switch 3 gangs:
Dear @Mariano_Colmenarejo, I Γnstalled the driver and tested with my switches. After a day of reboot the hub, clear the app cache and trial, I still need your help:
I can install this for some of my switches but there is a problem: there are 3 switches on a physical panel and 3 on the app, the first on the left maps correctly with the first switch on app. The second on the panel maps with the third switch on the app. So the second switch on app and the third button doesnβt works.
I still need the version with manufacture code is Lumi Vietnam for the 3 switch. (Lumi for the newer version, Lumi Vietnam for the older and I have both)
βββββββββββββββββββββββββββββββββββββββββββββββββββ
Name Zigbee Switch Mc
Version 2023-02-05T10:18:54.951374305
- id: "Lumi Vietnam/LM-SZ1"
deviceLabel: LM-SZ1 Switch
manufacturer: Lumi Vietnam
model: LM-SZ1
deviceProfileName: single-switch
Name Zigbee Multi Switch and Child Mc
Version 2023-02-05T10:16:28.688435477
- id: "Lumi Vietnam/LM-SZ3"
deviceLabel: LM-SZ3 Switch
model: LM-SZ3
deviceProfileName: three-switch
LUMi devices may not exactly comply with zigbee standards and could use custom clusters.
I added them to the driver because I saw that it used cluster 0006, but if they donβt work Iβll need to change them to the Zigbee Thing Mc driver to see all the information about the clusters and endpoints used
The switches with manufacture code is Lumi Vietnam are not working and the later version with manufacture code Lumi is working event it share the same DTH driver.
I look inside the DTH driver code in IDE and I think I know why the working one have mapping wrong buttons, it use 1 3 5 7 endpoint not 1234β¦ (Iβm not a programmer, just see the logic of things):
Hello. Looking for EDGE driver for Xfinity XHK1-UE Keypad. Also If anyone knows the correct way to unpair from network and reinstall. I cant seem to find the procedure on this one anywhere. This keypad is used to control my garage door and also notify me who used it (by code). Thank You
Hi!
Iβm looking for edge driver for HZC electric Water leak sensor (S900W-ZG). Could someone please point me out were to find one or could someone add one?
Hi Iβm kinda new to the whole ST edge driver thing, so please excuse me if this was already mentioned somewhere.
Iβve recently purchased a Zigbee Thermostat but couldnβt find any pre-existing edge drivers that will function with it properly.
Is there some sort of say to implement this / a way to fork an exisiting driver to customize it to my needs?
where does one find the fingerprint info to request an edge driver? when im in the IDE and click on a device, I thought the info used to be in the description of the device. Thanks
does anyone know if there is an edge driver for this button? https://a.co/d/1otzyDV
Itβs a 3 function button that is almost identical to the Ikea Dimmer button but the driver for the ST wonβt recognize it with the drivers I currently have installed. thanks.
