Thank you very much for the explanation. And also sorry for posting my question in the wrong request thread!
Has anyone looked at making a Sunsa wand integration? They have an open API.
just wondering if its possible to get Abode security hubs to work with smartthings? i saw that theirs a driver for hubitat. would be awesome if i could use it on smartthings!
Would be great to get the Hive Connect DTH translated across to an Edge driver. Itās the one missing piece for my home and @Alyc100 's DTH and Smart App was brilliant.
I sure would appreciate if this was done! I would not be the only one!
Most recent ST update has killed whatever edge driver was working for Daikin Heatpump.
Is there a newer preferred method to get this back in? on off set temp/mode is all gone. So frustrating, it worked 2 days ago.
If you find no driver available yet, see if you can find out if there is an API documented for the device, and/or if you have a link to the former Groovy driver on github. I might be able to help you.
Thanks.
I have been digging around quite a bit today. Have not found anything using the API or similar that i can modify and hack away at.
Documentation for the wifi control here:
And the original ST DTH from bendews:
I started looking at your web requestor as an option to play with but I am away from my LAN currently. Honestly all I care about is being able to turn it on to a temp and a mode or off via routine based on the internal temp gauge. First I lost my Netatmo integrations and now this, Wife buy-in is getting lower each day
If you find time to look, that would be fantastic.
Newbie here. Just was getting familiar with the community and I was wondering if there are any custom edge drivers for the Aqara FO2 sensors yet? Looking around, Iāve found very little information about them. Any help would be greatly appreciated.
Do you mean the Aqara FP2 presence sensor?
Yes, fat fingered my keyboard. Its a wifi device different than anything else Aqara makes.
It has a lot of functional similarities to the previous generation, the FP1, although that was a zigbee device, not Wi-Fi. Itās definitely an improvement over the FP1, but they do have a lot of similarities as well.
Govee home integration would be great. Used to work with a key, I was able to get a scene going with a motion detected. Now nothing
Govee has some new models which are Matter-compatible. Those should work with smartthings without requiring any custom code.
As far as other models, those use Wi-Fi, not Z wave, so I have moved your post to the appropriate thread.
Ah! Sorry, my bad. I do believe that it is wifi. Thanks for the info and for putting me into the right place!
Always remaining hopefull as knowledge and experience grows with the developers, a Heatmiser thermostat Lan integration would be appreciated
I have a version of this that I made in my personal time and made available as a special extra for SharpTools premium members. Feel free to PM me over in the SharpTools community and I can add you to the private group.
I am a huge fan of the FP2.
Put the work in on manually mapping your layout, tweak a few settings and follow a few tips then you can really nail it.
I have mine running fine in Google Home where it brings over zones. Less so on SmartThings.
How did you get ST to work with Aqara FP2?
Hi all,
Recently started my ST journey after using a Athom Homey since 2016. Most of my devices are sensors such as Aqara/Xiaomi and, after getting the hang of using Edge drivers, are working fine. Bit shocked about the crap Tuya integration which isnāt great but got it working by making Tuya scenes and connecting them to virtual switches.
What I cannot find unfortunately is a way to connect my Youless LS120 P1 energy meter. I can find some older posts on this forum dating from 2017/2018 but no recent posts involving Edge drivers. Is there anyone who might know if there is a way to integrate this simple but very good energy meter?
Thanks in advance!!
