PHYN Plus Integration
Hi all,
I am looking to get a Phyn Plus working with Smarthings, I didn’t found any info around here.
Thanks.
Looks like it supports ifttt so what is exposed through the ifttt channel you can trigger or control w/ smartthings… depending on what you want to do you may want to look at core/webcore too. Outside of that you have to write your own device handler.
I want to open/close, be able to see usage, leaks/alerts, plumbing check results, water pressure and temperature. Looks like they have the API closed.
Now I see, IFTTT has some options but I am already receiving texts from Phyn.
