I could use some help here:
I’m currently running the Home Connect Hub
I have 4 Philips Hue White 840 Lumens smart bulbs. Two of them work but I can’t get the other 2 to be found.
The 2 bulbs that work, were found and installed as a (ZLL Dimmer Bulb) automatically.
The other 2 can’t be found. I tried to install by the brand etc with no luck!
Keep in mind I’m not using the Philips Hue bridge. I also tried to install as a “Smarthings” bulb.
I tried to reset the bulb by turning off and on 6 times but didn’t reset.
I even reset my hub to Factory setting.
Is there a way to create a device handler code to work with my 2 bulbs that can be found?
I need to get these other 2 bulbs working.
Any help would be appreciated
Thank you and happy new year?
JAG
