Long shot this one! Not necessarily a question for ST, it might be one for Hue but I get he impression you guys are the fastest route to an idea!
I’ve got a solution for outside LED lighting. One of these:
Combined with some these:
https://www.amazon.co.uk/gp/product/B01E6SDU4E/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
Gives me 5m of controllable RGBW LED lighting for the grand total of circa 70 quid. They work well with no coding (requires a Hue bridge) and in my opinion look awesome. It took me 10 minutes to pair the controller with the hue bridge and then I had them in ST changing the colour. The LED strip above will give you full RGBW.
If you want them outside you’ll have to put the controller in a waterproof case (unless you put the controller inside and just extend the 12/24V supply). If you want to extend them beyond 5m you can connect multiple LED strips (just get the right PSU or use a booster).
My next requirement is an LED flood light. Think architectural up lighting and you’re on the right path! I also want to do this as cheaply as above. So here’s the question (finally):
Does anyone have a solution to that would allow me to use something like this:
With ST?
My basic requirement is an LED flood light that is controllable by either HUE or ST.
Thanks all.
