Not tried them yet but cant see why they wouldn’t…
successfully using A60, GU10 and garden spots all without problems (after firmware update).
What Simon said. If you do have trouble, just report back here and we can probably get it working. Since it’s not on the official fingerprints, it might need a bit of tweaking, but we’ve had success getting other Lightify lights working like the Surface and clear white led bulb
For instance, it might connect as a ‘Thing’ and require you to manually change the devicetype, and if that doesn’t work, we might have to slightly alter a devicetype for you.
I just got my Lightify Recessed Kit (RGBW) and it works ok with ST.
I did not find out yet how to set the color connected to a SmartApp. Currently, I’m only able to set the color manually.
Thanks guys for the quick reply back! I guess I will have to go and get me one and check it out. @Simon_Goldberger I do LOVE my garden lights!
@JohanJongsma The Smart Lighting app has a “turn on and set color” option you can use.
I got a couple of the BR30s recently and supposedly have a few A19 bulbs coming once Amazon actually has them in stock. Does anyone know if Smart Lighting will eventually be able to distinguish between sending a color (which uses the RGB LEDs in the bulb) vs setting a color temperature using the tunable white LEDs? The white color options in Smart Lighting don’t allow the bulb to use nearly as nice of a white range as these bulbs look when you first power them on or manually control them.
How are others automating between the white range and the color range?
@zj4x4 I do not see how to get this done. Can you give more precise instructions?
Thanks, Johan
Open the SmartThings app. Go to marketplace. Click Smartapps. Click SmartThings Recommends. Click smart lighting. These are Android instructions, it should be similar on Apple devices but I don’t own one so I don’t know for sure.
From that app you can create multiple lighting rules. If you are on a v2 hub they run locally so that they will work even if your internet is down.
I couldn’t find the quote, but it’s been stated that color temperature is on the short list for the next Smart Lighting update. These Tunable White bulbs have become really popular. They have a lot of bug fixes and such for Smart Lighting and they can’t do just a cloud fix since it runs locally for V2 users. I’m hoping in the next month or two.
Rule Machine. It does it all including allowing you to pick a custom color, rather than just from the pre-selected list. This is especially helpful when the prefab colors in Smart Lighting don’t translate well to your particular device due to color gamut differences.
question about OSRAM LIGHTIFY CLA 60W CLEAR.
hi, i bought 2 of these in AMAZON UK.
these r not the tunable ones - just white.
when i try to add then to my hub (v2), the hub is paring to it, but it gets the “thing” or “unknown” device name.
i can see it in the IDE, it has a zigbee id - but i can’t get it to work.
did someone managed to get it to work ?
thanx
They will work with a custom devicetype. Check out this post and the one it links to:
For some reason ST is having trouble targeting the correct endpoint on these ancillary bulbs.
Awesome, I missed that. Thanks
I love these lights. They fit nicely in my existing spots.
Anyone with the LED RGBW strip try using a different set of RGBW LED’s with the OSRAM power supply and Zigbee controller that comes with the kit? I need at least 12’ of LED’s with (4) right angle connectors which would be price prohibitive with the current way they have packaged their system.
After much fuzz, it is now pretty easy to get Lightify to work on Hue, but sadly not right out of the box. I have summed up here how to get the Hue bridge to control Lightify perfectly with color temperature control and completely shut off. There are however one or two pitfall to be aware of.
Are you saying you need the Hue bridge still? I thought the advantage was the Zigbee controller can be controlled directly by smart things.
Both the lightify and hue bulbs will pair directly to ST.
I think there are many who use the hue hub connected to st because it has a few more robust integrations / functions / interface.
Thanks Jason as that is what I thought. Now just gotta figure out if you can wire in other LED’s instead of their overpriced 2’ sections.
Referring to the led strip, I haven’t used any led strips(yet) but fibaro makes a strip controller to use a standard rgb strip with. And I could be wrong but the might have an rgbw controller as well.
My guess is that you probably could use a third party strip with the Osram controller, but would want to change it all out which might involve some soldering. Also I suspect if you do this coloring may not be the same.
Yup, Fibaro is an RGBW controller for strips. It’s zwave and works well with ST per the thread on it. If for some reason, you’re partial to zigbee, then the Dresden FLS-PP is an RGBW controller option. The W isn’t color tunable like with the Osram on either of these options though. The W is a separate on/off/dim option for white leds.
I didn’t know this and was looking at them. Thanks!
I can’t seem to get the color temp to work with the virtual dimmer. Is there anything I should check? I have tried the Sticks18 device type, the one listed as OSRAM in the IDE, and the generic Zigbee color temp device types. None seem to allow most smart apps or virtual switches, except Circadian, to set color temp.
I prefer the Zigbee color temp device type because it allows smart apps, such as smart lighting and Circadian to see the bulbs.
Hopefully there is some help available. Thanks!
