Hi,
I have recently installed a Orbit Iris Faucet water valve that works great for about 30-60 mins. After that it becomes completely unresponsive. I have tried the only two different DHT’s I can find and get the same result. The only way I can get it to work again is to disconnect and re-pair. The device is within 3m of the hub so it is not a connectivity issue.
I hear that many devices stop working if they have not sent or received a command for some time. Is there a bit of code that I can add to the DHT that will send a check in (or battery status update or similar) every 20 mins or so. Failing that any other ideas would be greatly appreciated
Cheers
Daniel
